| Prius Main Forum This is a discussion on Handling during a sudden stop within the Prius Main Forum forums, part of the Toyota Prius Forums category; I've had my Prius for about 10 days now and have been really happy with it except I was a ... |
| Not-THAT-Senior Member Join Date: Jun 2006 Location: Rockville, MD
My Car: 2006 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I've had my Prius for about 10 days now and have been really happy with it except I was a little put off by the handling. The other day, I had to brake fairly suddenly -- it wasn't that sudden because I never follow anybody closely, but I was probably going around 55 mph and realized that traffic ahead of me had slowed down a lot. I don't remember the road being wet or anything. When I braked, I felt the car swerve and I had to grab the wheel hard to regain control. Is this a common problem with the Prius? I don't have VSC. My previous car was a 1996 Infiniti and I felt it handled much better. Is there something I should be doing differently (apart from not braking so hard)?
__________________ 2006 Classic Silver Metallic with Grey fabric interior Took delivery 6/14/2006 Additions: Carpeted floor mats and chrome license plate frame |
| Junior Member Join Date: Apr 2005 Location: Columbus, Ohio
My Car: 2005 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(PriusRos @ Jun 26 2006, 05:32 PM) [snapback]276997[/snapback]</div> Quote:
My Car: 2005 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I am not sure if this is your case. When my front right tire was low on pressure, the car turns right when I brake. After I make both front tire the same pressure, it never happen again. |
My Car: 2005 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I have a 2005 Prius with VSC and also had to stop quickly on the freeway. The rear of the vehicle suddenly swerved almost in to the other lane. It appeared as if the brakes locked. Conditions were dry and temperature was warm. I assumed that ABS should have prevented this but I guess not. No real answers to the handling issue. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(mkaliski @ Jun 26 2006, 02:52 PM) [snapback]277003[/snapback]</div> Quote:
| Proud member of the "Lunatic Fringe" Join Date: Oct 2004 Location: Manhattan, KS
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | No problems here. The various safety features did their job (2005 Prius w/ VSC). Most memorable experience was when the traffic came to a sudden stop on the downhill of a highway. No swerving as you describe, although I could "feel" the car making some adjustments I was not, but then again, that's what those stability features are designed to do. I should add that some (perhaps most) drivers instinctively jerk the wheel when something suddenly happens in front of them, which consequently can cause a swerve and/or loss of control. Are you sure this is not the case in your situation?
__________________ Brandon 2005 Driftwood Pearl Prius, BC (Package #6), Delivered 10/21/2004 |
My Car: 2006 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(brandon @ Jun 26 2006, 08:07 PM) [snapback]277079[/snapback]</div> Quote:
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | If the tire pressure is normal, I would check the brake pads next. Even though, nowaday, pads are simply "floating" on rotors, sometimes, left/right sides simply grab the rotors differently. When braking hard, the vehicle may pull to one side. In addition, Prius is a front-heavy (59/41% front/rear) vehicle (like most front drive) with tall stand (higher than most sedans/coupes). When braking hard, the rear end would be lifted due to weight shifting forward. The rear tires would lost traction a little. Therefore, it may be more likely to fish-tail. Just my assessment. |
| "I think my Dad's gone CRAZY!" Join Date: Feb 2006 Location: Los Angeles
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | No problem here either. Just had to make a sudden stop the other day...everything went fine. I agree, a lot of driver's instinctivly jerk the wheel trying to avoid what is in front of them. It happens so fast that it is not a conscious reaction, so one would not remember doing it. Most of us are also used to pumping the brakes which is a hard habit to break with the new ABS systems. However, sounds like you did not crash, so I guess things worked as planned as far as that. |
| | #10 | ||
My Car: 2006 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(mssmith95 @ Jun 26 2006, 09:04 PM) [snapback]277103[/snapback]</div> Quote:
<div class='quotetop'>QUOTE(ceric @ Jun 26 2006, 09:01 PM) [snapback]277098[/snapback]</div> Quote:
Thanks for the input and suggestions, everyone. I'm a little disturbed that a couple of others seem to have experienced something similar, so it could be the car and not just me. I just hope that I can get used to the handling. | ||
| Bad gas? Sudden MPG drop. | Scott_R | Fuel Economy | 15 | 02-25-2008 12:09 PM |
| Sudden mileage drop | HenryE | Prius Main Forum | 7 | 03-19-2006 02:29 PM |
| Sudden movement | tootallrls | Prius Main Forum | 12 | 01-25-2006 04:09 AM |
| Sudden troubles with fill up | hdrygas | Care, Maintenance and Troubleshooting | 10 | 11-13-2005 12:12 AM |
| sudden low mpg | joycebasch | Fuel Economy | 6 | 08-12-2005 11:42 AM |
