Prius Main Forum This is a discussion on Nail in Rear Tire within the Prius Main Forum forums, part of the Toyota Prius Forums category; A good repair shop will not use plugs, only patches on the inside. If any part of the patch comes ...
Old 06-28-2006, 11:43 AM   #11
Prizzle
A good repair shop will not use plugs, only patches on the inside. If any part of the patch comes in contact with the curve of the beginning of the sidewall they will declare it unrepairable because tire flex can loosen the patch. Holes in the actual sidewall are unrepairable as well.
For $100 +/- mounted and balanced vs your life and maybe someone elses, it's worth it IMO to replace that tire rather than risk a plug.
I just went through two brand new front tires on my other car at $240 a pop for same situations. Painful but necessary.
'06 Super White "Prizzle", Package #8 (the works), raked side moldings, BT stiffener, Coastal auto-lock and 12V power always-on, Weathertech front and cargo mats, mudflaps, Kenwood sub-woofer, tossed trim rings, center speaker off, reverse buzzer mod
"Controversy, well executed, can work in your favor"
-Ralph Gilles
Prizzle is offline
rear tire wear - inside cupping Henry V Prius Technical Discussion 9 12-02-2007 10:55 PM
Dang, nail in my tire efusco Care, Maintenance and Troubleshooting 33 11-28-2007 10:03 AM
Dog nail imprints on driver side rear door edayres Care, Maintenance and Troubleshooting 1 11-16-2006 11:53 AM
NAIL in tire barbaram Care, Maintenance and Troubleshooting 9 10-13-2006 03:02 PM
nail in front tire 06 prius #8 5000 miles! pete bogumill Prius Main Forum 8 07-06-2006 04:33 PM
