Prius Main Forum This is a discussion on New Prius road noises is this common? within the Prius Main Forum forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(jamarimutt @ Jun 28 2006, 07:28 PM) [snapback]278403[/snapback]</div> Immense improvement also in mpgs? <_< [/b] I detected no discernable ...
Old 06-29-2006, 12:09 AM   #11
jbarnhart
jbarnhart's Avatar
I detected no discernable difference. I keep mine at 40/38.
jbarnhart is offline
Old 06-29-2006, 01:51 AM   #12
theorist
theorist's Avatar
Since installing very quiet Continental ContiProContact tires, I'm hearing all sorts of sounds I didn't notice before. It's sort of nice to be able to hear the HSD at work.
theorist is offline
Old 06-29-2006, 02:17 AM   #13
hobbit
hobbit's Avatar
Try the clean-off-the-rotors trick -- do a slowdown in neutral,
letting the physical brakes take all the load, and then see if
that changes anything..
_H*
hobbit is offline
Prius Noises ifosso Prius Technical Discussion 5 03-16-2007 12:57 AM
Prius noises! fatale Care, Maintenance and Troubleshooting 7 12-13-2006 12:54 PM
Common Problems with the Prius boostin Care, Maintenance and Troubleshooting 3 06-23-2005 01:17 PM
Prius giveaways- getting common? galaxee Prius Main Forum 1 04-28-2005 04:17 PM
Need help fielding common question regarding my Prius pdxprius Prius Main Forum 2 03-20-2005 09:22 PM
