| Prius Main Forum This is a discussion on The science/physics/math/safety behind overinflated tires... within the Prius Main Forum forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(David H. Hawkins @ Jun 29 2006, 11:44 PM) [snapback]278976[/snapback]</div> ... I doubt the rigidity of most tires will ... |
#41 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(David H. Hawkins @ Jun 29 2006, 11:44 PM) [snapback]278976[/snapback]</div> Quote:
Bridgestone RFT (Run Flat Tire), Dunlop DSST (Dunlop Self-Supporting Technology), Firestone RFT (Run Flat Tire), Goodyear EMT (Extended Mobility Technology), Kumho XRP, Michelin ZP (Zero Pressure), Pirelli RFT (Run Flat Technology) and Yokohama Run Flat. All of which have a semi-constant contact area that is not dependent on air pressure at least in the short term. The contact area is more complicated than your foumula. Sorry. That said, I do not dispute that tires with more air pressure role with less effort than the same tires with less pressure. I have experienced it. It is easy to feel on a bicycle. Me, I'm going to keep my tires somewhere between the Toyota recommended pressure and several pounds below the max pressure printed on the tire. | |
| | #42 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(pocketpenguin @ Jun 30 2006, 11:22 PM) [snapback]279492[/snapback]</div> Quote:
The second system, as used by Michellin, uses an internal structure, attached to the wheel, to support the tire when it goes flat. During normal driving, this structure provides no support, as you can see in the photo ![]() Notice that as shown above, the runflat support does not even come close to the road in normal operation. In either case, normal operation uses the air pressure inside the tire to support the car. Now I reallize my formulas are a very simplified stating of the problem, but they DO describe the FUNDAMENTAL relationship between tire pressure and contact patch size. I have never ridden on runflats, but if the sidewalls were sufficiently stiff to support the car under NORMAL inflation and driving conditions, I expect the ride would become extremely harsh and unpleasant.
__________________ "The Scarlet Pump-A-Nickle": Barcelona Red, #8 with XM, 3M clear bra, Weathertec window deflectors and cargo mat, rear bumper protector, mud guards and modified seat tracks for more rearward travel. | |
| | #43 |
| Senior Member Join Date: Mar 2006 Location: Cambria, CA, USA
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Dave, I have to agree that your formula is correct if we just consider the tire at rest. The absolute size of the contact patch must follow your formula, based on load weight and inflation pressure. But nobody cares about the tire when the car is parked. The behavior of the contact patch under dynamically changing conditions is of greater importance than its absolute size. When cornering, it's important that tire maintain contact across as much of the tread as possible, without too much "roll" of the tire. Add to this the behavior of the suspension and cornering performance becomes a very complex issue: if the alignment shifts during a hard corner, any tire will lift. When in a hydroplaning situation---even though the car is being supported by water---the behavior of the patch determines how the tire will expel water to maintain traction. We accelerate, brake, corner, and encounter rough and wet roads. That's when we care about the behavior of the contact patch. None of that behavior can be modeled by a single equation. |
| | #44 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Rick Auricchio @ Jul 2 2006, 04:40 PM) [snapback]280205[/snapback]</div> Quote:
| | #45 |
| Senior Member Join Date: Jun 2006
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | In the Winter people typically add even more air to compensate for the cold weather. In regards to tires wearing in the middlem due to over inflation, I have seen it many times, but then again I am always amongst car people, or commercial truckers, or other folks who make a living around transportation. My Uncle who recently retired ran a service station for 50 years. I have seen about everything in regards to tire wear. It is also possible that if the stock tire width for the Prius is slightly more narrow than the rim lip, that braking will cause the tire to slightly cup and as the sidewall compresses during the rear to front weight transfer. This could account for the abnormally high number of complaints about the outside footpront wear pattern even on properly inflated tires. this would be aggrivated by the taller sidewalls on the stock rims and would probably be lessened by a lower profile, or slightly wider tire.
__________________ 2002 Champion New England Dragway 2001 GM High Tech Shootout Winner 1999 Champion Oxford Dragway http://www.tntdragracing.com |
| | #46 | |
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(David H. Hawkins @ Jul 2 2006, 02:23 PM) [snapback]280223[/snapback]</div> Quote:
| | #47 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(David H. Hawkins @ Jun 29 2006, 10:29 PM) [snapback]278923[/snapback]</div> Quote:
All of the above analysis is first order, but higher order effects are not very significant. | |
| | #48 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | can anyone tell me if pirelli p3000 tires would help in mpg? <div class='quotetop'>QUOTE(theorist @ Jun 28 2006, 11:27 AM) [snapback]278080[/snapback]</div> Quote:
| | #49 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(frankk67 @ Aug 28 2007, 10:20 PM) [snapback]503557[/snapback]</div> Quote:
Rolling resistance is bad. | |
| | #50 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | really? all the reviews seem to rave about them being quiet and long lasting, i figured if they were 80k tires with a synthetic compound and an A/A rating on traction/temp. then if i added extra air, it might help increase mpg. so then what tires will increase mpg? what about other sizes like a 65 or wider tire? <div class='quotetop'>QUOTE(ohioflash @ Aug 28 2007, 09:32 PM) [snapback]503562[/snapback]</div> Quote:
| LinkBack to this Thread: http://priuschat.com/forums/prius-main-forum/20655-science-physics-math-safety-behind-overinflated-tires.html | ||||
| gordonfsnyder's bookmarks on del.icio.us | This thread | Refback | 01-27-2008 03:04 PM | |
| Frontier Science vs Consensus Science | F8L | Environmental Discussion | 15 | 11-07-2007 12:01 AM |
| Myth: there is a shortage of math and science in the U.S. | JackDodge | Fred's House of Pancakes | 21 | 11-02-2007 10:37 PM |
| Physics Questions!!! | jonathanrohr | Fred's House of Pancakes | 10 | 04-30-2007 07:09 PM |
| Physics Professor says WTC collapse caused by thermite | jared2 | Fred's House of Pancakes | 64 | 04-12-2006 04:41 PM |
| Prius 101 for the Physics Syncophant | EricGo | Prius Main Forum | 24 | 02-14-2006 01:05 PM |
