| Prius Main Forum This is a discussion on Gas pumping problem within the Prius Main Forum forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(jburns @ Jul 12 2006, 09:18 PM) [snapback]285366[/snapback]</div> I was somewhat concerned about this before I got my 06. ... |
| | #11 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(jburns @ Jul 12 2006, 09:18 PM) [snapback]285366[/snapback]</div> Quote:
| | #12 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | This used to happen to me all the time on my Mazda6 (all gas stations). I just started putting the nozzle 2/3 of the way in instead of the whole way and it never happened again. I'm only 4 tanks into the Prius though (~2000 miles) and it hasn't happened on it. I do still only put the nozzle 2/3 of the way in, although with the Prius it's because the nozzle is too hard to get out when fully inserted (it keeps getting stuck). |
| | #13 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I had this problem the first two times I filled up, but never since. As someone else mentioned, the secret is to pump relatively slowly (don't pull the handle up too far) - it doesn't take much to pump it, and it only takes like 15-20 seconds longer (shorter if you count the many stops and starts required to pump it faster). |
| Problems pumping gas | AOV | Care, Maintenance and Troubleshooting | 63 | 03-03-2008 04:06 PM |
| pumping gas | itsme | Prius Main Forum | 16 | 05-06-2007 02:19 PM |
| pumping? | barbaram | Fuel Economy | 14 | 09-21-2006 12:51 AM |
| Is the A/C really on when it's pumping heat | mtsarpilot | Prius Technical Discussion | 4 | 08-27-2006 06:17 PM |
| Solutions for gas pumping issue? | jlbeerhour | Care, Maintenance and Troubleshooting | 31 | 07-26-2006 02:06 PM |
