| Prius Main Forum This is a discussion on 2006 Nav Over ride while in motion within the Prius Main Forum forums, part of the Toyota Prius Forums category; I'm new to the forum, and was really hoping someone out there might have a solution to the 2006 Prius ... |
| Junior Member Join Date: Aug 2006 Location: Virginia
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I'm new to the forum, and was really hoping someone out there might have a solution to the 2006 Prius NAV system as to HOW to over ride the gray out while in motion? I've noticed several topics on other models, but NOT on the 2006 as of yet. Anyone got any ideas or knowledge as to how without purchasing anything or messing up the warrenty?[color=#330099] |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Welcome BatteriesIncluded (cool screen name btw). I'm also fairly new (2-3 weeks) on the forum. There's a couple of threads on this, just use the search function and start reading - I've found you can get the answer to most questions we who are new have. I couldn't find the exact thread I was looking for to give you (running out of time right now), but the gist is that some PC members came up with workarounds to defeat this feature on some of the earlier models, but one does not yet exist for the '06 (although I imagine work is afoot). Coastal Etech also sells NavPicks, but does not yet have the '06 fix available. Someone please correct me if this info is inaccurate. Guess I did have the time: type in: "2006 Nav/BT Fix" at the search page
__________________ 2006 Classic Silver Package #7 aka "The Silver Surfer" BT Stiffener Plate (Prius "Viagra"), 2" Coastal Receiver, Front Grill Blocking, Trim rings removed, Prius decals, Chrome Realtor license plate frame 2001 Kawasaki Vulcan 800 Custom At the moment of commitment, the universe conspires to assist you. |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | As of right now, no software solution has been found. The Coastal Lockpick that's for both NAV and BT may work, but only if it connects to the MFD. I have no proof, just a guess. There is another solution, but it requires cutting wires. Behind the A/C vent cover to the right of the MFD is two purple wires. The top wire is the speed sensor for the NAV, and the lower is for the BT. You cut them and install a switch on each. Then you (or rather, your passenger) flips the switch off, enters the information, and flips it back on. Some have installed a magnetic switch so by moving a magnet (in one case a Disneyland refrigerator magnet) you can enter information. That's very inconspicuous. I have a 2005, so I didn't cut the upper wire, but I did cut the lower one (for the BT) and installed a push-on/push-off button. You can see what I did here and here. Take a look at http://www.darelldd.com/ev/prius_speed_wire.htm (scroll to the bottom) to see where the wires are.
__________________ "Blue Belle" Seaside Pearl Purchased April 16, 2005 MODS: Wheelskin Steering Wheel Cover, GT Seat Covers, DashTopper Dash Cover, MFD Sun Hood, Pioneer AirWare XM radio, DICE Silverline iPod Integration, BT Override, Goodyear ComforTreds, Coastal Tech's Auto-Lock kit, NAV Enhancement kit & EV mod |
| Member Join Date: Jul 2006
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(aaf709 @ Aug 2 2006, 09:36 AM) [snapback]296341[/snapback]</div> Quote:
| Prius jerks while in motion | eucalyptic | Prius Technical Discussion | 8 | 10-17-2007 10:24 PM |
| wire to disable the motion sensor of the NAV | bhaynnes | Prius Main Forum | 3 | 09-18-2007 12:05 PM |
| Is it safe to use B while the car is still in motion? | Jaqueh2 | Prius Technical Discussion | 5 | 07-01-2007 10:42 PM |
| Motion override switch 2006 | Alnilam | Audio and Electronics | 20 | 11-21-2006 04:36 PM |
| clicking noise while in motion | SDiego | Prius Main Forum | 8 | 11-27-2005 09:11 PM |
