| Prius Main Forum This is a discussion on Do I need to run out of gas again to see if the tank really holds 11.9 gallons? within the Prius Main Forum forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(Presto @ Aug 17 2006, 10:18 AM) [snapback]304736[/snapback]</div> The tank is able to hold 11.9 Gal, but if you ... |
| | #11 | |
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 11 | <div class='quotetop'>QUOTE(Presto @ Aug 17 2006, 10:18 AM) [snapback]304736[/snapback]</div> Quote:
| | #12 | |
| my other Mobile Suit is a ... Join Date: Feb 2005
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Tideland Prius @ Aug 17 2006, 11:21 PM) [snapback]305168[/snapback]</div> Quote:
| | #14 |
My Car: 2007 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I've read reports that unless you're moving vigorously (sloshing the fuel around the bottom of the tank), you can't pump the last gal. or so of fuel out of the tank. Some who have run out found adding 1 gal didn't help them get it started. They had to add two gal. before it started again. This makes sense re your experience. BTW, this gal. of fuel you can't use in the bottom of the tank is not a bad thing. This is where you will find any water that got in, any dirt that got in, etc. Further, running out of fuel is not good for the fuel pump, which is cooled by the fuel it pumps. Each time you run out, it will be overheated for a short time before it shuts off.
| | #15 | |||
| Senior Member Join Date: Nov 2005 Location: La Mesa California
My Car: 2005 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Rancid13 @ Aug 17 2006, 11:09 AM) [snapback]304762[/snapback]</div> Quote:
<div class='quotetop'>QUOTE(galaxee @ Aug 17 2006, 11:10 AM) [snapback]304764[/snapback]</div> Quote:
<div class='quotetop'>QUOTE(RichBoy @ Aug 17 2006, 04:19 PM) [snapback]304933[/snapback]</div> Quote:
| | #16 |
| Senior Member Join Date: Oct 2004 Location: Dallas TX
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I treat my Prius like any car I've owned. I add fuel BEFORE lack of fuel could become a problem. In my Prius, usually at the last UN-BLINKING blip. Most often, I note the fuel prices and fill at one of the lowest I've seen. |
| Intelligence Chief Holds Class for Rightards | EricGo | Fred's House of Pancakes | 28 | 07-26-2007 01:08 PM |
| Low fuel warning came on with 3 gallons still in the tank | Soylent | Prius Main Forum | 29 | 09-13-2006 10:06 PM |
| gallons to fill an empty tank | kente777 | Prius Main Forum | 9 | 11-22-2005 06:44 PM |
| What holds your Documents and Manuals? | priusham | Prius Main Forum | 51 | 03-23-2005 07:44 PM |
| Prius holds it's value incredibly! | Ray Moore | Prius Main Forum | 7 | 11-11-2004 01:26 PM |
