Prius Main Forum This is a discussion on Turning MFD OFF within the Prius Main Forum forums, part of the Toyota Prius Forums category; So, since I have discovered the joys of using the mechanical key to lock and unlock and leaving the Pri ...
Old 08-17-2006, 02:02 PM   #1
rufaro
WeePoo with WeePri
rufaro's Avatar
Send a message via Yahoo to rufaro Send a message via Skype™ to rufaro
Friends: 35
So, since I have discovered the joys of using the mechanical key to lock and unlock and leaving the Pri ON when running very short errands (since most of my use is very short distances, and I am p***ed at the low mileage I get and don't want to have the "warm-up" cycle start every time), I also discovered the trick of turning the dash lights way down (so they'll go off after a while) and the screen "OFF" button. The problem is that the MFD OFF does NOT seem to be a toggle like all the others: I have to fidget and fiddle and do all sorts of contortions to just MAKE THE SCREEN STAY BACK ON. Intuitively, it SHOULD work thusly: DISPLAY to SCREEN OFF and OK. Then, DISPLAY ON OK...but it doesn't. Sometimes it seems to require I put the car in gear and sometimes...something else I can't figure out.
I HAVE read the manual...it does not address this issue, anywhere I can find it anyway.
Any ideas?
AKA WeePriQueen & Member of Hot Chicks in Black Prii club.
rufaro is offline
Old 08-17-2006, 02:06 PM   #2
Rancid13
Cool Chick with a Black Prius
Rancid13's Avatar
Package: #8
Send a message via AIM to Rancid13 Send a message via Yahoo to Rancid13
I've found in the past when I've turned the MFD off that in order to get it to remain on when you turn it back on, you have to push a few buttons around it (ie: toggle between climate, audio, info, etc). One shouldn't have to do that, but I've found that if I turn it on and leave it alone, it shuts off again unless I start pushing buttons.
Rancid13 is offline
Old 08-17-2006, 02:09 PM   #3
rufaro
WeePoo with WeePri
rufaro's Avatar
Friends: 35
<div class='quotetop'>QUOTE(Rancid13 @ Aug 17 2006, 11:06 AM) [snapback]304758[/snapback]</div>
That's what I mean...and it never seems to be the same sequence. Hmmm...do we need a consultation with our local PriTech dh (HEY GALAXEE...YOU LISTENING?)
rufaro is offline
Old 08-17-2006, 02:16 PM   #4
Proco
Proco's Avatar
Hmmmm ... I just hit the "info" button on my steering wheel and it stays on just fine.
Proco is offline
Old 08-17-2006, 02:16 PM   #5
maknowlton
Well, the other day I was playing around with the screen off (in traffic jam, so I was in drive the whole time). Had the same problem - but when I hit the info button once, and then the (trip info?) icon, (I think-- the left-most one, at any rate) it brought me back to normal (energy screen, with MFD on).
Wasn't really intuitive, at any rate.
maknowlton is offline
Old 08-17-2006, 02:20 PM   #6
KMO
Package: T Spirit
I think you just need to get to trip info or the map screen. If you hit CLIMATE or AUDIO, and you've got the "automatically return" option enabled, then it will go back to off after a delay, just as it would go back to INFO or MAP.
KMO is offline
Old 08-17-2006, 02:23 PM   #7
Rancid13
Rancid13's Avatar
Package: #8
<div class='quotetop'>QUOTE(KMO @ Aug 17 2006, 11:20 AM) [snapback]304768[/snapback]</div>
I've had my "automatically return" option disabled on mine for quite some time though...
Rancid13 is offline
Old 08-17-2006, 02:23 PM   #8
rufaro
WeePoo with WeePri
rufaro's Avatar
Friends: 35
<div class='quotetop'>QUOTE(Proco @ Aug 17 2006, 11:16 AM) [snapback]304766[/snapback]</div>
Note, please, I have package #3--no info button on steering wheel and no map screen. And it doesn't work consistently with using the info button next to the MFD.
rufaro is offline
Old 08-17-2006, 02:26 PM   #9
Proco
Proco's Avatar
<div class='quotetop'>QUOTE(Rufaro @ Aug 17 2006, 02:23 PM) [snapback]304771[/snapback]</div>
Ah. I thought the info button on the steering wheel would be standard. My bad.
Proco is offline
Old 08-17-2006, 02:31 PM   #10
theorist
theorist's Avatar
This reminds me how in Calcutta, many drivers would go through the city at night without turning on their headlights. They reasoned that if they could see without the headlights the driving/parking lights would be enough for others to see their car. Certainly headlights are more important than LCD and LED displays, but so is the energy consumption.
Last weekend a Bengali cousin was visiting and was surprised that I turned my headlights on during the day. He was really surprised to notice that most cars had their headlights on, even after I explained the reasoning behind daytime running lights.
theorist is offline
ICE keeps turning on during commute philaprius Fuel Economy 9 11-29-2007 07:05 PM
turning off beeps callmetuck Prius Technical Discussion 3 09-22-2007 04:50 PM
Turning to greener wheels jkash Prius and Hybrid News 4 01-19-2007 05:40 PM
Bluetooth after turning off car tacomel Audio and Electronics 2 08-16-2006 11:39 AM
squeak while turning murray1207 Care, Maintenance and Troubleshooting 5 11-10-2005 06:44 AM
