Prius Main Forum This is a discussion on Tire Pressure does make a difference! within the Prius Main Forum forums, part of the Toyota Prius Forums category; I'd been driving my new Prius, with whatever pressure was in the tires when we took possession of it. In ...
Old 09-04-2006, 09:57 AM   #1
harper42
harper42's Avatar
I'd been driving my new Prius, with whatever pressure was in the tires when we took possession of it. In my every day running around, I'd been averaging about 45 mpg. Went on a 600 mile trip and got 50.6 mpg and was quite happy with that. THEN..... I checked the tire pressure. It was only around 34. I upped it to 40/38. With the next 200 miles....... with my every day running here and there, we are getting better than 53 mpg!! I'M A BELIEVER! Tire pressure really does make a difference!
harper42 is offline
Old 09-04-2006, 10:27 AM   #2
Rangerdavid
Rangerdavid's Avatar
Friends: 7
All 4 of my tires were somewhere around 32, I upped them all to 38, and we're averaging 50.1 on this tank around town so far. In the past my tanks have averaged 47.8, so i am getting a slight increase as well.
I think I may pump them up to the 40-38 like you did and see how that goes....
Rangerdavid is offline
Old 09-04-2006, 10:58 AM   #3
harper42
harper42's Avatar
<div class='quotetop'>QUOTE(Rangerdavid @ Sep 4 2006, 07:27 AM) [snapback]313953[/snapback]</div>
I've heard of others going even higher; but I was a little nervous about any more pressure than I gave them. What are the rest of you using?
harper42 is offline
Old 09-04-2006, 12:02 PM   #4
seasalsa
seasalsa's Avatar
Send a message via AIM to seasalsa
<div class='quotetop'>QUOTE(dulcimer @ Sep 4 2006, 07:58 AM) [snapback]313965[/snapback]</div>
According to the last poll the majority of us were running 42/40.
Here is the link to the poll.
http://priuschat.com/index.php?showtopic=2...e+pressure+poll
seasalsa is offline
Old 09-04-2006, 12:07 PM   #5
Lola&#39;05
Lola&#39;05's Avatar
Post
40/38. And I am happy with the ride, handling and mpg.
Lola&#39;05 is offline
Old 09-04-2006, 12:32 PM   #6
Tideland Prius
Super Moderator
Tideland Prius's Avatar
Friends: 11
38/36 at the moment.
Toyota's recommended is 35/33
Tideland Prius is offline
Old 09-04-2006, 02:19 PM   #7
PriusRos
Not-THAT-Senior Member
PriusRos's Avatar
<div class='quotetop'>QUOTE(seasalsa @ Sep 4 2006, 12:02 PM) [snapback]314000[/snapback]</div>
I think that poll is a little extreme, to say the least, and you can't say what the majority of people are running at based on the answers. Except for the Toyota recommended pressure of 35/33, I think the LOWEST choice in the poll was 40 or 42. The highest was over 100 -- but thank goodness, nobody said they were doing that. At least one person said their tires were at 60psi all around.
PriusRos is offline
Old 09-04-2006, 02:24 PM   #8
Rancid13
Cool Chick with a Black Prius
Rancid13's Avatar
Package: #8
Send a message via AIM to Rancid13 Send a message via Yahoo to Rancid13
I had my DH check my tires for me a couple weeks ago (hey, I'm over 6 mo. pregnant...I gotta make him do some stuff for me!) and they were previously at 35/33 so I had him 'up' the pressure to 40/38. I had been getting some 'low' mileage tanks at 46-47mpg (which I really had to try for) and since the pressure was increased I've easily been getting 48-50mpg tanks. So I think tire pressure really does make a difference. I may eventually go the PC-recommended pressure route and get them up to 42/40 but I'm happy with the current pressure as is.
Jennifer
2006 Black Pkg #8 w/bisque leather
"Max" (Prius Maximus)
Rancid13 is offline
Old 09-04-2006, 03:33 PM   #9
jamarimutt
Yes, higher pressures do make a difference. You will have more rattles and the suspension will wear down sooner.
Other forum members have found no significant difference between the factory recommended pressure and overinflated tires.
jamarimutt is offline
Old 09-04-2006, 03:42 PM   #10
mcbrunnhilde
Opera singin' Prius nut!
mcbrunnhilde's Avatar
<div class='quotetop'>QUOTE(jamarimutt @ Sep 4 2006, 12:33 PM) [snapback]314103[/snapback]</div>
Have you seen the max pressure on the sidewall? It's 44 cold psi. How do you see 42/40 as overinflation?? Let's see...am I going to take a car maker's word for what tire inflation should be, or should I maybe possibly perhaps be guided by what the actual manufacturer of the tire says? Wow, that's a real poser, that one....
Bear in mind that Toyota recommended 35/33 on the Classic Prius, and that was with Bridgestone Potenzas that had a 50 psi rating. I believe that after MANY complaints of premature wear due to underinflation (and replacements of prematurely worn tires) they quietly issued a TSB to their dealers that jacked the "recommended" pressure to something like 42/40.
Still think Toyota has better judgement?
Pat
2004 Salsa #7/AM "Gracie"
mcbrunnhilde is offline
tire shop broke a TPMS tire pressure monitor sensor during tire change theorist Care, Maintenance and Troubleshooting 28 04-18-2008 12:53 PM
Breaking in period does make a difference harper42 Prius Main Forum 11 10-11-2006 04:28 PM
Simple mods that make a big difference nyprius Prius Modifications 34 09-29-2006 05:51 PM
Added amp make that much of a difference? Color Theory Audio and Electronics 2 01-31-2006 10:43 PM
What a Difference 50 Years Can Make!! DaveinOlyWA Fred's House of Pancakes 8 11-28-2004 08:31 PM
