| Prius Main Forum This is a discussion on 3 Beeps? within the Prius Main Forum forums, part of the Toyota Prius Forums category; Sometimes when I turn the car off and leave the SKS in my hand or purse, the car will beep ... |
| Senior Member Join Date: Jul 2006
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Sometimes when I turn the car off and leave the SKS in my hand or purse, the car will beep 3 times. I cannot figure out what this is. It seems to only happen at home. The only thing different about work or home is I never lock my car at home and I always lock it at work or while shopping, etc. Can someone help me....and yes, I searched here and I have read the manual and can't find this problem. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(benighted @ Sep 10 2006, 03:59 PM) [snapback]317437[/snapback]</div> Quote:
My usual sequence of events is to pull in the driveway, put my foot on the brake, pick up my keys or my purse, hit the power button and open the door. All this is done rather quickly in my driveway. Could it be a timing thing? Maybe it thinks I am leaving the car before it is all the way off? The only reason I think this could be the answer is I probably am a little slower to leave the car at work. Does the bluetooth connection beep? Sometimes my phone will show a bluetooth connection in the house when the car is sitting in the driveway. Today, when it beeped,though, the phone did not show a bluetooth connection. | |
My Car: 2005 Prius Package: #5 Nominated 5 Times in 3 Posts TOTM Awards: 0 Friends: 21 | is this an inside beep or an outside beep? or both? if it thinks you're leaving the car with the smartkey in hand and the car still on, it'll give one long beep inside and three short beeps outside. i don't recall offhand (don't do this often) but if you try to do something the car doesn't want you to do (park while still moving, etc) i think it gives you 3 beeps. i'll have to check on that. don't have BT so i'm not sure about that, hopefully someone else can answer that for ya.
__________________ black 2005 prius, tweaked just the way i like it my diagnostic guy on electronics: "lack of troubleshooting ability is due to a high common sense rejection ratio." |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(galaxee @ Sep 10 2006, 04:35 PM) [snapback]317443[/snapback]</div> Quote:
| Progressive Member Join Date: May 2004 Location: Southern California
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Renocat @ Sep 10 2006, 01:05 PM) [snapback]317439[/snapback]</div> Quote:
__________________ Justice, justice you shall pursue. (Deuteronomy 16:20) | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(IsrAmeriPrius @ Sep 10 2006, 07:19 PM) [snapback]317504[/snapback]</div> Quote:
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 24 | I bet you're not turning it off..I know, it seems unlikely, but that's the only thing that would beep 3 times, outside the car, after exiting with a smart key. |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(efusco @ Sep 10 2006, 05:06 PM) [snapback]317525[/snapback]</div> Quote:
I know I turned the car off. I turned it on and off again at least five times and it kept on beeping when I tried to lock it after I verified that the car was off. Once I unplugged the DVD player, the car stopped beeping and locked when I pressed the black button on the door handle. Perhaps there is some circuit that keeps something on after you turn the car off when an electronic device is still plugged in even though all the indicators are that the car is off. | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(efusco @ Sep 10 2006, 08:06 PM) [snapback]317525[/snapback]</div> Quote:
| Beeps | jdunleav | Prius Modifications | 3 | 02-03-2008 11:14 AM |
| Reverse Beeps and JBL | wilco | Audio and Electronics | 8 | 11-03-2005 03:53 PM |
| How do I disable the MFD beeps? | GameMaker | Audio and Electronics | 2 | 06-30-2005 09:00 AM |
| Two beeps or not two beeps | Godiva | Prius Modifications | 2 | 04-24-2005 08:03 PM |
| Stopping the BEEPS | PetersPrius | Audio and Electronics | 4 | 04-19-2004 06:00 PM |
