Prius Main Forum This is a discussion on Alignment - How Much Toe In? within the Prius Main Forum forums, part of the Toyota Prius Forums category; Our month old 06 Prius is getting an alignment tomorrow afternoon. I keep seeing that the alignment, and a slight ...
Old 09-11-2006, 08:27 PM   #1
Claudia
Our month old 06 Prius is getting an alignment tomorrow afternoon. I keep seeing that the alignment, and a slight toe in, will help that "wandering all over the road" feeling I get when driving, and the constant need to correct the steering.
Exactly what degree of toe in should I request at the dealership? I'm really hoping to get this right the first time, 'cause next stop is the tire store! Anything in particular that I should know before having this done?
Claudia is offline
Old 09-11-2006, 08:52 PM   #2
majordude
<div class='quotetop'>QUOTE(Claudia @ Sep 11 2006, 05:27 PM) [snapback]318064[/snapback]</div>
Exactly what degree of toe in should I request at the dealership?[/b]
+0.05 Front
+0.15 Rear
majordude is offline
Old 09-12-2006, 01:50 AM   #3
Claudia
<div class='quotetop'>QUOTE(majordude @ Sep 11 2006, 08:52 PM) [snapback]318078[/snapback]</div>
+0.05 Front
+0.15 Rear
I thought only the front end needed alignment - didn't know the rear could be anything but something called "shimmed", which isn't advised.
Anybody verify if I've got it right?
Claudia is offline
Old 09-12-2006, 08:08 AM   #4
kDB
<div class='quotetop'>QUOTE(Claudia @ Sep 12 2006, 12:50 AM) [snapback]318177[/snapback]</div>
Anybody verify if I've got it right?[/b]
you are correct, but they should still check to see if it is in the specifications margin.
kDB is offline
Old 09-12-2006, 11:25 AM   #5
Claudia
<div class='quotetop'>QUOTE(kDB @ Sep 12 2006, 08:08 AM) [snapback]318231[/snapback]</div>
Thanks - we'll be sure they check. I'm going to ask for a printout.
I think some people get their 000s and decimal points confused - I've seen recommendations for +.005 to +.01, and yet I think the right amount is +.05 to +.1 on each front side.
Unless somebody says otherwise in the next hour and a half, I guess we'll go and ask for a +.05 toe in on each front side, and to be sure that the rear is "within specs".
Claudia is offline
Old 09-12-2006, 12:39 PM   #6
sydgurley
<div class='quotetop'>QUOTE(Claudia @ Sep 12 2006, 11:25 AM) [snapback]318314[/snapback]</div>
The toyota alignment sheet says front toe angle range is -0.10 to 0.10, so ideally the toe in setting should be 0 However slight toe in would be better for stability, but too much will wear the inside of the tire. My prius was +.27 on the left and -.36 on the right and was corrected to -0.03/-0.01. THis caused a major improvement in highway cruising stability/handling. Be careful about the plus and minus-- not sure of the sign convention for toe in and toe out.
sydgurley is offline
Old 06-14-2008, 10:13 PM   #7
Ichiro
Ichiro's Avatar
Default Re: Alignment - How Much Toe In?
Just got my Prius aligned today
Before alignment:
Front toe was "+0.12 / -0.20" and steer ahead was "0.16" ... all of these numbers were "red" on the report.
After alignment:
Front toe is "0.00 / 0.00" and steer ahead is "0.00"
Haven't had a chance to drive on the highway yet, but I'm hoping to see a big improvement in high speed stability.
Ichiro is offline
Old 09-12-2008, 02:34 PM   #8
ystasino
I got my Prius aligned today, it has 19600 miles and is an 07 model which was pulling left quite a bit.
Before alignment toe was "+0.15/-0.16"
After alignment toe was "0.00/0.02"
Now I'm guessing my numbers don't justify the conclusion but from 8 miles of commute I don't think it's pulling left now. The tech only saw minor tire wear on the left front.
ystasino is offline
Got alignment done Tony_Min Care, Maintenance and Troubleshooting 8 05-28-2007 08:16 PM
Alignment ? DGH Care, Maintenance and Troubleshooting 5 08-29-2006 03:26 AM
Alignment? grasshopper Prius Technical Discussion 22 06-07-2006 09:24 AM
alignment eak354 Care, Maintenance and Troubleshooting 10 04-26-2004 02:18 AM
Got alignment done Tony_Min Prius Main Forum 0 12-31-1969 07:00 PM
