Prius Main Forum This is a discussion on MFD replacement questions within the Prius Main Forum forums, part of the Toyota Prius Forums category; I experienced the MFD issue described in multiple posts and appreciated reading through everyone’s experience. It always makes you feel ...
Old 11-28-2006, 06:40 PM   #1
shocker
I experienced the MFD issue described in multiple posts and appreciated reading through everyone’s experience. It always makes you feel better knowing what the problem is and how it can be solved.
My ’04 has 50,850 miles and the dealer stated that they could order a refurbished unit for 592.00. I called the 1800.331.4331 number to plead my case that this is a problem not based on wear and tear of the car and that my car isn’t even 3 years old. They were extremely polite and sympathetic but stated that I had to negotiate directly with the dealer who I then called back and wouldn’t budge. After I started using the phrase “good faith” as suggested in a post here on the forum they offered 10% off.
Is it unusual for the 800 number to refer me back to the dealer? Has anyone been successful in having Toyota cover the cost even when you exceed the 36,000 mile clause in the TSB?
Thank you in advance for any responses!
shocker is offline
Old 11-28-2006, 06:51 PM   #2
Tideland Prius
Super Moderator
Tideland Prius's Avatar
Friends: 11
Toyota usually wouldn't cover. They covered 1/2 the cost of our Camry's A/C problem (cause it straddled the warranty timeline).
Check the thread that Galaxee made WRT to the MFDs and ordering them.
Tideland Prius is offline
Old 11-28-2006, 07:22 PM   #3
Cheap!
Cheap!'s Avatar
Get a refurbished MFD and save the money
Cheap! is offline
Old 11-28-2006, 09:21 PM   #4
jrmgkia
Wish I was cycling
jrmgkia's Avatar
My situation was almost identical to yours and I was successful at getting Toyota to foot half of the bill, which was 1,000 dollars including labor. I did a little write up about my experience at http://www.law2.byu.edu/millerj/cars/2004prius/more.htm check out the link for some ideas on how to make a good case for yourself, and let us know if you are successful. Good luck.
jrmgkia is offline
Old 11-29-2006, 09:01 AM   #5
galaxee
running WOT until out of fuel
galaxee's Avatar
Nominated 5 Times in 3 Posts
Friends: 20
that's about the price you're going to see for a refurb. around here they're $470something plus tax and installation. around 50k the chances of having a full good faith coverage are getting pretty low, unfortunately.
galaxee is offline
Old 12-01-2006, 10:24 PM   #6
GeronimoPFudgemuffin
<div class='quotetop'>QUOTE(galaxee @ Nov 29 2006, 09:01 AM) [snapback]355176[/snapback]</div>
around here they're (refurb MDF) $470something plus tax and installation
Is replacing the MFD something I could do in my garage? I've been an auto mechanic (in a past life) but don't know if doing this requires Toyota special XYZ-tool at $3500 (or whatever).
My buddy has a fragged one in his '04 and I told him I'd be willing to do it if, and only if, it's "do-able" by me.
GeronimoPFudgemuffin is offline
Old 12-01-2006, 10:53 PM   #7
galaxee
galaxee's Avatar
Friends: 20
GPF-
it's just ripping apart the dash panels, no scantool required.
however they're pretty nazi-ish about the whole exchange process for refurbs... they won't let you outta the shop with a refurb until they've got the defective one back.
galaxee is offline
Old 12-01-2006, 11:21 PM   #8
hill
High Fiber Member
hill's Avatar
<div class='quotetop'>QUOTE(shocker @ Nov 28 2006, 07:40 PM) [snapback]355012[/snapback]</div>
So ... does this mean you didn't get the extended waranty? Mine was replaced under that ~ & they paid 100%. No way of telling whether it was a rebuild or not ... but at the time (say about a year ago) it took 3 or 4 weeks for it to "come-in". I don't know if that meant, "rebuild another one" ... or, "order another from Japan".
hill is offline
Old 12-02-2006, 10:08 AM   #9
shocker
Unfortunately, yes, that means I didn't buy the extended warranty. I was naive and figured that if something was going wrong with the cars and that Toyota recognized it was a problem then they would cover the repair of the faulty area. Sigh.... lesson learned about the harsh world.
shocker is offline
Old 12-02-2006, 10:57 AM   #10
Blegate
Blegate's Avatar
Question, does anyone know what exactly is going wrong with the units? In other words what is being fixed in the units? Is the problem a poor solder job, failed IC, or are ribbon cables just being reseated?
Just curious......
-B
Blegate is offline
European Prius 2007 Questions, questions montecarlomonaco Audio and Electronics 0 10-25-2007 05:18 PM
Is a replacement 12V battery necessary? magneto99 Care, Maintenance and Troubleshooting 4 12-12-2006 11:08 AM
Brake pad replacement pafoss Prius Main Forum 13 05-14-2006 11:19 AM
Tweeter Replacement dgstan Audio and Electronics 7 03-29-2006 05:00 PM
Replacement Horn jomilt Prius Modifications 0 07-02-2005 02:39 PM
