| Prius Main Forum This is a discussion on Slick 50 or other additive? within the Prius Main Forum forums, part of the Toyota Prius Forums category; Has anyone added a product like Slick 50 or Mystery Oil... you know the stuff that claims to get you ... |
| Junior Member Join Date: Dec 2006 Location: Los Angeles
My Car: 2007 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Has anyone added a product like Slick 50 or Mystery Oil... you know the stuff that claims to get you better mileage, less wear and so on? Results? I am tempted to try it on my brand new '07... it did seem to help when I added it to my 10 year old Integra. The bottle says it will not void any warranty, and it even comes with its own... but I've never seen it mentioned on the boards. Thanks. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I'm glad you asked that, 'cause now I can finally contribute something here! I was wondering the same thing a while ago and called the manufacturer of Slick 50. They recommended that Slick 50 NOT be used because the ICE would not get hot enough to initially distribute the teflon particles after putting in the Slick 50. |
My Car: 2004 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 8 | <div class='quotetop'>QUOTE(icharry @ Dec 20 2006, 06:59 PM) [snapback]364847[/snapback]</div> Quote:
On my Prius I am sticking to Mobil 1 (a synthetic oil) which should protect the engine without any extra additives. I suggest that you consider also using a synthetic oil even though the cost is noticeably higher than so-called "Dino" oil. JeffD | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I would STRONGLY suggest not using Slick50 or similar additives. At best, it won't help. At worst, it could do real damage to your engine. Here's why. Teflon (PTFE) is a solid, not a liquid. In Slick 50, the PTFE is a solid held in suspension by the carrier oil, almost like chocolate powder mixed in a glass of milk. You may be thinking that tiny particles held in suspension in your oil is just what an oil filter is designed to remove...and you'd be right. So its debatable how much PTFE will actually circulate in your engine. Next, Teflon must be applied at over 700 degrees for it to bond to metal surfaces. Very few parts of your engine will reach those temperatures, so virtually no bonding will actually occur as described in the advertising. And the parts which might actually have deposits would, by definition, change the incredibly tight tolerances. Which is probably not a good thing. Finally, the particles tend to clump together and can plug small oil passages. If a Teflon coating would help, Toyota would do it themselves. There are quite a few sites on the Internet on this topic, but a good one is: http://skepdic.com/slick50.html
__________________ 2007 Touring Edition Prius, Magnetic Grey, Package #6 2002 Porsche Boxster S 2004 Honda Element (my other Box-ster) |
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 9 | <div class='quotetop'>QUOTE(jdenenberg @ Dec 20 2006, 04:59 PM) [snapback]364864[/snapback]</div> Quote:
If you want to go crazy, use synthetic oil and stay away from the snake oil. | |
| Senior Member Join Date: Dec 2006 Location: Somewhere, NY
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(jamarimutt @ Dec 22 2006, 06:27 AM) [snapback]365597[/snapback]</div> Quote:
I wouldn't put Slick 50 in any motor, but I put Mobil 1 in every motor, including my Briggs & Stratton lawnmower. Mobil 1 used to have an advertising ploy, the "oilpan test." The chintzy oilpan on my Ford Taurus wagon started leaking due to a minor scrape, which together with some rusting caused a small leak. I had a local garage replace the oilpan. When I picked the car up the mechanic asked me if I had changed the oil that morning, it was in such good condition. I had changed it three weeks earlier. Before I left the garage, I wandered over to where the old oil pan was. It was sparkling clean, not even a hint of sludge. Mobil 1 was right, and I wound up doing my own "oil pan test." Mobil 1 will not sludge up, ever, and will keep oil passages clean. It will also get where it needs to go quickly, under adverse conditions like below-zero temperatures, when conventional oil acts like molasses. Synthetic oil is superior, it's just a question of whether you will pay extra for it. Harry | |
| Senior Member Join Date: Aug 2005
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(darelldd @ Dec 21 2006, 02:27 AM) [snapback]364955[/snapback]</div> Quote:
So are we going to have to schedule a deposition? Will he be a bit less "smug?" (See the backlash from regular drivers thread.) OK, OK, I admit, I'm so jealous of his great achievements I can barely drive my Prius in gasoline mode. I've been staying up nights trying to fit the solar panels on the roof of anything I own. He's said he doesn't even care about the property tax issue!!! And to think I suggested that he could be President. | |
| CA40 gas additive | dnep | Fuel Economy | 3 | 08-29-2007 05:25 PM |
| BioPerformance additive | figmentor | Prius Main Forum | 6 | 03-08-2006 06:51 PM |
| Oil additives - Slick 50 etc.... | CLJohnson72 | Prius Main Forum | 3 | 03-02-2006 04:09 PM |
| Slick 50 | richardsprius | Care, Maintenance and Troubleshooting | 1 | 11-28-2005 08:47 PM |
| Slick 50? | len | Care, Maintenance and Troubleshooting | 7 | 09-17-2004 01:47 PM |
