Prius Main Forum This is a discussion on Hi! within the Prius Main Forum forums, part of the Toyota Prius Forums category; Hey, welcome to Priuschat. So far you've picked up a few good tidbits. For an example of real-world mileage, please ...
Old 03-14-2007, 11:44 AM   #11
Priapus
Alter Ego
Priapus's Avatar
Hey, welcome to Priuschat. So far you've picked up a few good tidbits. For an example of real-world mileage, please check the mileage logs availble at http://www.chicagopriusgroup.com. You will find other things about the Prius there as well. I've tried to make the site enlightening for both Prius owners and people smiply interested in the Prius without bombarding the reader with details.
Additionally, depending on where in Ohio you live, perhaps a Priuschat member would be willing to give you a test drive and more hands-on opportunities.
Priapus is offline
Old 03-14-2007, 12:42 PM   #12
MacDude
MacDude's Avatar
Send a message via AIM to MacDude
Hi there and welcome!
I'm just shy of 6'5" and the only thing that I can say is that occasionally I have to lean forward a bit to see overhead stop lights if I'm first or second in line. I even fit in the back seat (important because my 14-year-old son is closing in on 6' and already has bigger feet than I do.)
I tried to fit in the Honda hybrid and there was no way I was gonna last more than an hour or so. My son wouldn't fit in the back and neither would my wife (who is 5'10").
MacDude
2007 Super White Touring Edition
MacDude is offline
Old 03-14-2007, 02:09 PM   #13
IsrAmeriPrius
Progressive Member
IsrAmeriPrius's Avatar
<div class='quotetop'>QUOTE(efusco @ Mar 14 2007, 06:46 AM) [snapback]405338[/snapback]</div>
Other than that there are few 'minuses'...[/b]
Let me add, mediocre handling, lack of sound insulation (most noticeable at highway speeds) and the worst OEM tires I have had on any car I had owned since my 1967 Dodge Dart.
IsrAmeriPrius is offline
Old 03-14-2007, 02:37 PM   #14
brick
brick's Avatar
<div class='quotetop'>QUOTE(IsrAmeriPrius @ Mar 14 2007, 03:09 PM) [snapback]405556[/snapback]</div>
I think handling issues and the tires go hand-in-hand. Change the tires, get more traction, experience better handling. My snow tires (soft, sticky, and one size wider) seem to be be better in corners. But braking performance seems pretty good to me, and I think that's most important unless you're trying to set a lap record. I now realize that those snow tires were doing a number on my fuel economy, too. But it beats getting stuck!
Noise may not be an issue for the OP depending on how his Element compares to the 2002 Accord that I was driving before the Prius. That thing was loud on the highway and especially in the rain. It was as if Honda decided not to use any sound deadening at all. The Prius is quieter than that car was. But it's not in the same league as something like a big Lexus, which is kind of like driving a cloud.
I don't know. I'm 6'1 and I like mine. I commute 17 miles on 70% back roads, 30% 65mph highway, and drive plenty of highways on the weekend. Average since buying in December is just shy of 50mpg with conservative but reasonable driving. Doing 58mpg this week since morning temps got above freezing.
brick is offline
Old 03-14-2007, 02:40 PM   #15
jgills240
jgills240's Avatar
I'm 6'1" and my only issue with fit is that the steering wheel needs to be adjustable toward the driver, not just up and down. although i've gotten used to it in less than a month, and don't even notice it anymore.
Mediocre handling - I'm not doing any 4+ G turns, but I have noticed no lack of handling.
The armrests should be higher & more padded.
oh, and the shifter should be up for Drive and down for Reverse. just makes more sense.
Other than that, I absolutely love it!
jgills240 is offline
Old 03-14-2007, 04:17 PM   #16
hisshers
How are they in the snow?
hisshers is offline
Old 03-14-2007, 04:43 PM   #17
Betelgeuse
Betelgeuse's Avatar
<div class='quotetop'>QUOTE(hisshers @ Mar 14 2007, 04:17 PM) [snapback]405643[/snapback]</div>
To say that there is much disagreement on the performance of the Prius in the snow is a gross understatement. There are some (myself included) that have been amazed at how well the Prius performs with its stock tires. However, I should point out that I'm not in a serious winter climate. Southern New England certainly gets snow and ice, but it's nothing near the level that other places get. The consensus from most people in places that get real winters is that, with the stock tires, the Prius is anywhere from "OK" to "bad" in the snow. However, with decent tires, most people are pleasantly surprised about how the Prius does in the snow, even in those places. I should point out that these "decent tires" are not necessarily snow tires, although snow tires obviously help even more.
One thing to realize is that the car does have relatively low clearance between the bottom and the ground. This means that it is definitely possible to "bottom out" the car in deepish snow. But this is no more true than on many other sedans.
Some people complain about the so-called overly-aggressive traction control making winter driving impossible. I have never had a problem with this. Our car (again, with stock tires) has performed admirably in the snow that we get here.
Betelgeuse is offline
Old 03-14-2007, 04:45 PM   #18
pewd
Clarinet Dude
pewd's Avatar
Package: #1
I'm 6'5" - its a bit tight around the knees- have to be careful getting in and out.
I occassionally hit the shift lever with my knees - I wish it was 2" higher.
Try another (longer) test drive - get in and out several times - make sure its going to work for you.
I'm averaging 48mpg - its going up as the weather continues to warm up.
The last tank was 50mpg.
About triple the mileage of the jeep I traded in. For that, I'll put up with the tight leg room.
pewd is offline
Old 03-14-2007, 06:44 PM   #19
IsrAmeriPrius
Progressive Member
<div class='quotetop'>QUOTE(brick @ Mar 14 2007, 12:37 PM) [snapback]405572[/snapback]</div>
...and I think that's most important unless you're trying to set a lap record.[/b]
No lap records, just the ability to safely complete emergency avoidance maneuvers without losing control.
Old 03-14-2007, 09:27 PM   #20
brick
brick's Avatar
<div class='quotetop'>QUOTE(IsrAmeriPrius @ Mar 14 2007, 07:44 PM) [snapback]405716[/snapback]</div>
Ehh...I still don't think the Prius is lacking anything important. What we experience in a Prius is a fair bit of body lean as a result of the soft-ish suspension. At the absolute handling limits you will get understeer and the sound of tires squealing, which is an engineered response to tell the driver "Hey, I can't hang on much longer!" If I modified your suspension with some stiffer springs and a set of 30mm sway bars you would probably interpret the experience as "better handling." In reality all I would have done for you is remove the tactile feedback (body lean and progressive understeer at the limits) and replaced them with a nasty surprise at the end, which is a sudden loss of grip and a probable loss of control. Again, the true handling limits will come down to your tires, and again I agree that you can do much better than stock in that respect. But I assure you, the car has what you need to maintain control in an emergency avoidance maneuver provided that you do have clear space into which to steer.
brick is offline
