Prius Main Forum This is a discussion on Battery within the Prius Main Forum forums, part of the Toyota Prius Forums category; I just bought a 2007 Prius. I've noticed that when I don't use it for two days, the Energy Monitor ...
Old 04-04-2007, 06:55 PM   #1
grubmans
I just bought a 2007 Prius. I've noticed that when I don't use it for two days, the Energy Monitor indicates that the battery is down to 2 purple bars. I have 2 questions: (1) Is this normal? (2) I'm planning on leaving the car for a two week trip. Will the battery be dead when I return? I know to turn off the Smart Key. Thanks for your help.
grubmans is offline
Old 04-04-2007, 07:24 PM   #2
Tideland Prius
Super Moderator
Tideland Prius's Avatar
that shouldn't happen unless you left it at 2 or 3 bars the last time you shut it off.
I'd be more concerned about the 12V battery. Turn off the SKS, headlight, dome light, cargo light and vanity light (i.e. move all of them to the OFF position).
Tideland Prius is offline
Old 04-04-2007, 07:41 PM   #3
grubmans
<div class='quotetop'>QUOTE(Tideland Prius @ Apr 4 2007, 08:24 PM) [snapback]417889[/snapback]</div>
Hi Tideland: Thanks for the reply. I asked two questions. Which question were you answering? (1) Is it normal for the battery to discharge down to two purple bars after two days of nonuse? (BTW, the battery was at 6 purple bars when I turned off the car). Or (2) Will the battery be dead if I leave the car for two weeks? Thanks for the advice about turning off the inside lights.
grubmans is offline
Old 04-04-2007, 07:50 PM   #4
San_Carlos_Jeff
San_Carlos_Jeff's Avatar
<div class='quotetop'>QUOTE(sheana @ Apr 4 2007, 05:41 PM) [snapback]417898[/snapback]</div>
Hi Tideland: Thanks for the reply. I asked two questions. Which question were you answering? (1) Is it normal for the battery to discharge down to two purple bars after two days of nonuse? (BTW, the battery was at 6 purple bars when I turned off the car). Or (2) Will the battery be dead if I leave the car for two weeks? Thanks for the advice about turning off the inside lights. [/b]
Losing 4 bars in two days is definitely not normal. I doubt you should lose any in two days. Are you sure you're turning the car off completely?
I've left my car for two weeks and when firing it back up didn't notice any change in the battery (although it could have dropped a bar or two).
San_Carlos_Jeff is offline
Old 04-04-2007, 07:54 PM   #5
grubmans
<div class='quotetop'>QUOTE(San_Carlos_Jeff @ Apr 4 2007, 08:50 PM) [snapback]417902[/snapback]</div>
I turn the car off by pressing the "P" to put the car in Park and then I press the "Power" button. I hate to sound stupid but (maybe I am!!!) do I need to do anything else to turn the car off completely? Do I have to separately turn off the radio or the bluetooth?
grubmans is offline
Old 04-05-2007, 12:02 AM   #6
JimN
Certified Prius Advisor
JimN's Avatar
<div class='quotetop'>QUOTE(sheana @ Apr 4 2007, 07:54 PM) [snapback]417905[/snapback]</div>
Turning everything off before powering down is a good habit to get into. From your description I don't believe you are doing anything that should be draining the battery. Sounding stupid is one thing. Being stupid is another. You were smart enough to buy this car. Sooner or later everyone is going to make a bonehead mistake that is either going to cost a little money or inconvenience. There is no such thing as a stupid question. If something bothers you, ask. This car has many unique characteristics and there are many helpful experts here. Welcome to the site. (For the record, I don't believe for a second Sheana is stupid.)
Does the condition persist when the radio & bluetooth are turned off?
2006 Magnetic Gray "Spirit Queen" TP 45, Blocked grill, Toyota rear bumper applique, VentureShield panels: Hood, bumper & headlights
2000 Intrigue "Lil Deuce Coupe"
1999 EV-1 Range 220 miles
2000 Precept diesel-electric hybrid 80mpg
The reason I own a Prius. Thank you, GM.
JimN is offline
Old 04-05-2007, 12:53 AM   #7
Bill Merchant
absit invidia
Bill Merchant's Avatar
Nominated 6 Times in 1 Post
Friends: 47
Talking
Hi Sheana, welcome to PriusChat! I agree with Jim that the only stupid questions are the ones a person is too pig-headed to ask.
When you hit the Power button and the little car with the key starts blinking on the dash lights, the High Voltage battery is completely disconnected from the car, only the little 12 volt battery is powering things. Your HV battery level should be the same as when you turned it off after only two days, unless the weather gets very cold. A cold battery won't put out as much power as a room-temperature one, nor will a hot battery, so use your AC down there in Florida, for your battery's sake...
I'd suggest taking it to the dealer and ask them to test the HV battery. While highly unlikely, it's possible you got a defective one; there have been a few reports. If you need a new HV battery, it is covered by warranty.
Since the 12V battery is small, eliminating as many power drains as possible is a good idea when you leave the car for over two weeks. One particular problem has been the cargo light. It can be left on by mistake and the tonneau cover pulled so you don't see it and it can suck the 12V battery right down.
All that said, I've left my 2005 at the airport for 10 days without turning anything off (I never use the cargo light though) and it started right up, just as I had left it.
Bill
2007 NL 5 Silver Wraith
2005 BC 6 Silver Cloud
Portland Area HSD Meetup Group: PortlandHSD.info Become carbon neutral: Carbonfund.org or TerraPass.com
Bill Merchant is offline
Old 04-05-2007, 01:47 AM   #8
snowdog650
snowdog650's Avatar
<div class='quotetop'>QUOTE(JimN @ Apr 4 2007, 10:02 PM) [snapback]418030[/snapback]</div>
Sounding stupid is one thing. Being stupid is another.[/b]
Jim ... this is one of your better quotes. I think I'll use this in my conference call tomorrow.
snowdog650 is offline
Old 04-05-2007, 08:47 AM   #9
grubmans
<div class='quotetop'>QUOTE(snowdog650 @ Apr 5 2007, 02:47 AM) [snapback]418088[/snapback]</div>
Hi All-
Thanks for the great replies!!!
grubmans is offline
Old 04-05-2007, 09:51 AM   #10
Walker1
Walker1's Avatar
Send a message via Yahoo to Walker1
Exclamation
[quote=sheana @ Apr 4 2007, 07:55 PM) [snapback]417871[/snapback]</div>
I bought 2 battery tenders for 2 of my vehicles. They keep a battery] 12 volts or so and only put a trickle charge in when the voltage drops to around 10 volts. I used to get dead batteries in my motorcycle and yard tractor, but not since I put battery tenders on both. They are well worth the $40 I paid for each one. No more dead or low batteries.
Walker1 is offline
Why the small battery icon atop the hybrid main battery? sparlin Audio and Electronics 3 02-07-2008 08:58 AM
What's the 4-bar +/- battery symbol above the Hybrid battery meter on the MSD? seakykr Prius Technical Discussion 6 10-20-2006 03:39 PM
12 VDC Aux Battery (AB) andyprius Care, Maintenance and Troubleshooting 15 12-05-2005 08:38 PM
Battery on the MFD Battery Meter JShorr Care, Maintenance and Troubleshooting 11 01-05-2005 03:52 PM
12 v battery toolbox Care, Maintenance and Troubleshooting 21 10-17-2004 07:46 PM
