Prius Main Forum This is a discussion on What is the A/C switch for? within the Prius Main Forum forums, part of the Toyota Prius Forums category; Another small point, alaskaprius, is that the AC compressor is electric, so if only a little cooling is needed for ...
Old 04-07-2007, 02:32 AM   #11
Bill Merchant
absit invidia
Bill Merchant's Avatar
Nominated 6 Times in 1 Post
Nominated TOTM Awards: 1
Friends: 53
Talking
Another small point, alaskaprius, is that the AC compressor is electric, so if only a little cooling is needed for dehumidification, it only runs a little at low speed.
The biggest problem most people have with the Air Conditioning (A/C) system is when they just want fresh air from outside, without heating or cooling, maybe in June there. You set the temp setting to its lowest, then turn off the AC screen button to stop the compressor. More complicated than a Vent button.
Bill Merchant is offline
Old 04-07-2007, 12:15 PM   #12
zijlstra
zijlstra's Avatar
<div class='quotetop'>QUOTE(Bill Merchant @ Apr 7 2007, 02:32 AM) [snapback]419283[/snapback]</div>
Thanks for all the good info. BTW, unlike what most people might think about Alaska, it can get quite hot up here, esp. in the interior parts of Alaska, which can go into the upper 90s. I've used the A/C in previous cars plenty of times to cool down the vehicle during the summer, so I'm glad the Prius includes A/C
zijlstra is offline
Old 04-07-2007, 04:55 PM   #13
Bill Lumbergh
USAF Aircraft Maintainer
Bill Lumbergh's Avatar
Package: #1
....and since it's above 40 degrees outside today, I'm running around in a t-shirt.
Bill Lumbergh is offline
Steering Wheel Switch Lighting & Door Rest "Auto" Switch Lighting Susan4ET Prius Technical Discussion 1 10-04-2007 08:43 PM
EV Switch - What has it done to your MPG? bigmahma Prius Modifications 22 05-19-2007 10:05 PM
EV SWITCH roso Prius Main Forum 2 05-26-2005 07:21 PM
EV Switch ? tntna Prius Modifications 43 01-12-2005 12:50 PM
EV Switch tntna Prius Modifications 0 11-29-2004 10:10 AM
