| Prius Main Forum This is a discussion on A/C - Fresh / Recirculated within the Prius Main Forum forums, part of the Toyota Prius Forums category; Hello - My Prius automatically chooses whether to use fresh or recirculated air, which I find to be somewhat unfortunate ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hello - My Prius automatically chooses whether to use fresh or recirculated air, which I find to be somewhat unfortunate seeing as how I'm usually driving behind a gross polluter. Does anybody know how to set the A/C to recirculated air and then prevent the car from changing to fresh? Thanks! |
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 11 | <div class='quotetop'>QUOTE(bondrew @ Apr 25 2007, 09:10 AM) [snapback]429831[/snapback]</div> Quote:
The moment you press any button (from AUTO mode), that respective mode becomes manually operated. e.g. if you touch the fan speed, then the fan speed becomes manually operated but the mode (head, head/feet etc) is still automatic. With recirc, if you manually close the vent, then it'll stay in recirc until you open it. | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Tideland Prius @ Apr 25 2007, 08:13 AM) [snapback]429834[/snapback]</div> Quote:
Yeah, I do manually press the recirculate button, but it turns itself off occasionally. Also, when I turn the car on, it typically defaults to fresh. I usually use the recirculate button on the steering wheel...any chance that that makes a difference? | |
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 11 | <div class='quotetop'>QUOTE(bondrew @ Apr 25 2007, 09:16 AM) [snapback]429836[/snapback]</div> Quote:
It'll turn off if you press AUTO A/C as well but it should stay when you toggle the front defroster. | |
My Car: 2007 Prius Package: #5 Nominated 6 Times in 1 Post TOTM Awards: 1Friends: 52 | On both my 2005 and 2007, if I have the AC in recirc when I shut the car off, when I start it again it is in recirc and stays that way. Lotta stinky F150s and log trucks in Oregon... |
| air conditioner: how to get fresh air into the car | avboone | Prius Main Forum | 14 | 04-13-2008 08:53 AM |
| A/C fresh and recirculate settings | Dr Ed | Prius Technical Discussion | 1 | 07-06-2007 08:53 AM |
| Fresh Air | Deanlu22 | Prius Main Forum | 2 | 05-24-2007 06:23 AM |
| Energy and fresh water? | burritos | Environmental Discussion | 2 | 02-23-2007 01:57 PM |
| Must the AC compressor run just to get fresh air | cdavid | Prius Main Forum | 5 | 04-17-2006 10:43 AM |
