Prius Main Forum This is a discussion on Emergency Brake within the Prius Main Forum forums, part of the Toyota Prius Forums category; rear brakes are adjusted with use of the parking brake. if you search on this, there are a few discussions ...
Old 05-03-2007, 10:54 PM   #11
galaxee
running WOT until out of fuel
galaxee's Avatar
Nominated 5 Times in 3 Posts
Friends: 21
rear brakes are adjusted with use of the parking brake. if you search on this, there are a few discussions on this.
galaxee is online now
Old 05-04-2007, 08:30 PM   #12
Tideland Prius
Super Moderator
Tideland Prius's Avatar
Friends: 11
yeah but not just the brake itself but the cable needs to be tightened once in a while.
You'll noticed when it's tightened (or if the car is new), you need to apply quite a bit of pressure to depress the E-brake pedal. As you use it, it becomes easier to press and you have to depress it a greater distance.
So next time you bring it in for service, have them tighten the cable.
Or, just lightly use the e-brake so you don't loosen the cable too quickly.
Tideland Prius is offline
Emergency Brake Assist PriusOwner004 Prius Main Forum 14 10-09-2007 10:27 AM
Adjusting the emergency brake? gforeman Prius Main Forum 10 09-08-2007 08:05 PM
Emergency brake use? Mary Snyder Prius Main Forum 9 12-03-2006 12:07 PM
Leak near emergency brake pedal HokieHybrid Care, Maintenance and Troubleshooting 10 06-08-2006 12:19 PM
Emergency brake indicator malfunction ThetaSigma99 Care, Maintenance and Troubleshooting 4 03-07-2005 02:39 PM
