| Prius Main Forum This is a discussion on Energy Dump? within the Prius Main Forum forums, part of the Toyota Prius Forums category; Evan: I don't quite get understand one thing. What can I do driving down a long hill to avoid charging ... |
| | #21 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Evan: I don't quite get understand one thing. What can I do driving down a long hill to avoid charging the battery to the point of having the engine cycle on/off when I stop at the red light at the end of the hill? What and how would I use the energy wasted by the on/off ICE cycle. Ah, coasting down the hill in neutral would avoid excessive charging, but then we get into the argument of whether it's good or bad to coast in neutral. :mrgreen: |
| | #22 |
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | a large hill might be better to coast at least part of the way in "B" mode. although toyota does warn that B mode should only be used for short periods at a time. |
| | #23 | |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 24 | Quote:
Again, this is not always achievable and without knowing your exact route I can't say if you can avoid that condition or not. I know I had 2 places that I used to energy dump pretty routinely. Since using more glide and hyperstealth/stealth I don't energy dump at all and haven't for many months. | |
| | #24 |
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | but what is the no arrows mean?? that mean the car is using power out of thin air? or is it simply a level of power that sits in the transition area where regen, battery and ICE meet? obviously the power must come from one of these sources. and you must have some petal pressure on the gas to achieve this so the power is most likely coming from a combination either one depending on whether the power demand is going up or down. i think the no arrow mode is just a bug in the display. |
| | #25 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | if you look at my post about interesting results http://www.priuschat.com/forums/viewtopic.php?t=3506 you will see when the battery gets to 80% full charge you can't regen any more but if you put it in B mode you get a current draw of 18 amps and the bsoc slowly sinks. |
| | #26 |
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | i know the SOC display's range is from 30-70% but i didnt realize that a 100% charge was not possible. i figured to prevent overcharging they would cut it off at a higher level than that like 90-95% i would think. i know that for charging purposes, exact rates arent possible because to many physical conditions affect the effective charge rate including temperature, humidity, etc. but i would think that they would be able to get closer than that since everything is controlled by the computer, i would think that the computer would monitor outside influences and be able to charge higher in the usually rare cases of a large downhill. although in another sense, i can see toyota's rationale for not wanting to take chances with overcharging since extremely dry conditions could easily increase the charge rate considerably. i guess they wanted a maximum safe margin in all possible weather situations. still a slightly larger battery would be nice...(if i keep mentioning this in every post, do you think they will get the hint?)
__________________ My 2006: Last tank 463.1 miles @49.2 pump (49.4 computer) 4.22 cpm winter mpg 50.70 summer mpg 54.59 lifetime: 33,038.3 miles 52.79 mpg pump (54.04 mpg computer) 5.74 cpm My 2007 Zenn Driven 5849 miles, 2.00 cpm/ 105 mpg (at $2.05/gal), 4.04 miles/ Kwh Savings over my Prius $300.79 The Corolla...567.79 The REAL SAVINGS from not driving Corolla 657.39 +Prius= 958.18 (excludes maintenance costs...would be unfair to ICE vehicles) My Plate: DUALPWR (Dual Power) |
| | #28 |
| Senior Member Join Date: Jan 2004 Location: Oakland, CA
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | There is not any chance to practice techniques involving the accelerator. The accelerator is only lightly touched in the tunnel. It is never touched from the tunnel exit until leaving the traffic light at the end of the off-ramp (and even then, just enough to hit the peak of a small rise 50 feet past the signal). There is not much chance to practice anything except holding off on braking. Even then, I am usually braking only for control on the slight curves or to fit in the traffic flow (did I mention the lightly used onramp from another freeway just before my offramp?). |
| | #29 | |
And yes, there definately are conditions where extra Ah of battery could help. There's an ongoing project that I'm not free to discuss doing exactly that with great success so far. I know of at least 3 people who currently have additional battery storage with 4th due in the next couple of weeks. Hilly conditions are a good place...extensive city driving is another place it helps. But even on hwys, for some reason (prob. due to decreased internal battery resistance) they're seeing 10-15% improvements in mileage. | |
| | #30 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | just a thought on the use of extra battery capacity, if you pull down the larger battery and then have to run the ICE longer to get it changed to the point where the computer will allow the vehicle to go into hybrid mode, you have used the extra fuel to achieve your results of having more capacity. For most usage the current setup seems to be well thought out. There will always be exceptions to this but for the most part and most users I doubt that another 3-4,000 dollars worth of batterys will be justified |
| Vatican airlines passengers must dump holy water | markderail | Fred's House of Pancakes | 6 | 08-31-2007 02:52 PM |
| Fusion Energy | DaveinOlyWA | Environmental Discussion | 2 | 12-10-2006 02:57 PM |
| Should I dump the cheaper further gym? | burritos | Environmental Discussion | 6 | 07-07-2006 03:29 PM |
| Energy Use | niepo | Prius Technical Discussion | 6 | 06-13-2006 01:15 PM |
| Time to dump those puny little girly-man Hummers | jimvitz | Other Cars | 0 | 09-13-2004 01:56 PM |
