| Prius Main Forum This is a discussion on Window Tint within the Prius Main Forum forums, part of the Toyota Prius Forums category; Juat got the Prius and 48.3 MPG coming home over the space of 40 miles. My question is, will tinting ... |
| Member Join Date: Apr 2007
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Juat got the Prius and 48.3 MPG coming home over the space of 40 miles. My question is, will tinting the windows really interfere with the navigation system? The owners manual says there is "metal" in the tints and is is not recommended....what is your opinion? |
| Shire rat Join Date: Feb 2007 Location: Dallas
My Car: 2007 Prius Package: #5 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | There might be some tints that are metallic in nature. I'm thinking here about those silvery-looking ones. But I can vouch for my tint. It does not interefere with the GPS reception. Here is a pic: [attachmentid=7860] |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(TomorrowMatters @ May 5 2007, 08:18 AM) [snapback]435977[/snapback]</div> Quote:
I still maintain that Priuschat is one of the best - if not the very best Prius forum on the internet. | |
My Car: 2007 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The GPS antenna works through the windshield. Most jurestictions don't allow windshield tinting, so it wouldn't affect the GPS anyway. Most tinting film does contain metal, and will attenuate the GPS signal if you tint the windshield. Whether it causes problems or not would depend on the tint you used. BTW, it also attenuates radar and laser, so detectors become less sensitive. |
| my other Mobile Suit is a ... Join Date: Feb 2005
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(John6012 @ May 5 2007, 04:45 AM) [snapback]435964[/snapback]</div> Quote:
Here's the old Tinting 101 thread: http://priuschat.com/index.php?showtopic=9473&hl= And a general search: http://www.google.com/search?q=site%3Apriu...lient=firefox-a But basically, any metalized content in tint will block/reflect EM signals weakening it for GPS and cellphone reception. Since the GPS antenna is behind the display facing the windshield, try not to use metalized tint there. Why does metalized tint exist? Because it generally has the best solar IR rejection abilities. Much like modding cars, some tint for looks and some do it technical improvement. | |
| Junior Member Join Date: Apr 2007
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Most vehicles that have the GPS antenna inside put it on the rear deck somewhere. My old Acura did this, and I believe a number of other Honda products had the same design. We tested with metallic tint material and found that it did have an adverse impact on GPS reception when placed (we used some scrap pieces) over the antenna. To deal with that problem, we used the FormulaOne Pinnacle tint material which is ceramic based. It's a lot more expensive, but had no impact on the GPS signal. The only other alternative would have been a dye-based tint film, which tends to fade. The system will generally try to rely as much as possible on satellites that are 45-75 degrees above the horizon. Satellites that are straight up tend to not allow for as good triangulation, although using one straight up combined with two off to the sides gives very accurate results too. Satellites lower on the horizon are very susceptible to interference. What this means for the Prius is that the location of the antenna forces it to pretty much focus on satellites that are visible through the windshield. Anything that might possibly be visible through some other window is going to be so low on the horizon that every building, tree and truck will cause intereference. So, unless you tint your windshield (which is illegal in most places), you should have no problems. Heavy metallic tints can theoretically impact cellphone reception as well, but cellphone signals are much more powerful than GPS, and I have never had a problem. That said, I found the FormulaOne Pinnacle (ceramic) to be one of the best tint materials I have ever owned in terms of function. I got superb heat and glare reduction even with a relatively light (50%) tint, and none of the metallic look that you get from many metal-based films. I'm considering it again, but haven't decided for sure. Going to talk to my local tinter tomorrow. -btc
__________________ 2007 Prius Touring Barcelona Red/Bisque Light tint all around SiriusPrius Bridgestone Potenza G019 Grid 195/55-16 on stock wheels |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(BTC @ May 8 2007, 11:34 PM) [snapback]438070[/snapback]</div> Quote:
| Considering a Window tint | Prius The First | Prius Modifications | 88 | 06-23-2008 04:35 PM |
| Considering a Window tint | Prius The First | Prius Main Forum | 15 | 04-01-2007 07:32 AM |
| Window tint and GPS- Help, please | olcorral | Prius Main Forum | 4 | 05-02-2006 04:54 PM |
| Window Tint | km5er | Fred's House of Pancakes | 1 | 01-17-2006 11:24 PM |
| What window tint Film did you go with | cpooler | Prius Modifications | 5 | 05-28-2005 01:18 AM |
