Prius Main Forum This is a discussion on 185/65/R14 on 2001 Prius within the Prius Main Forum forums, part of the Toyota Prius Forums category; I'm thinking about installing 185/14/R14 Goodyear ConforTred on my 2001 Prius. Is it compatible? If so, do I need to ...
Old 05-15-2007, 02:13 AM   #1
nitewolfgtr
My Car: 2001 Prius
I'm thinking about installing 185/14/R14 Goodyear ConforTred on my 2001 Prius. Is it compatible? If so, do I need to do any modifications to the speedometer?
Also, how big of a hit am I going to take on MPG?
nitewolfgtr is offline
Old 05-15-2007, 10:56 AM   #2
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 7
I have 185/65R14 Nokian i3 on 2001 Prius. This width tire is accomodated by the wheel wells with no interference. I even suppose that there is room enough for Z-cables, but have not actually tried them.
Based on circumfrence, your odometer/speedometer reading will be about 2% slow (if it was accurate to begin with), and the fuel economy 2% low. You typed '14' instead of '65' for the profile I presume?
Your speedometer is not adjustable, or if it is, Toyota has not revealed the secret.
The above is a separate matter from the fuel economy 'hit' from wider tires, which will probably be about the same magnitude. Hard to make a more certain prediction on mpg, as it depends on that tire's construction and (markedly) on how you inflate them. The first 1000 miles or so on any new tire are a bit worse, until the sharp edges are 'rounded off' a bit. If you have previously been keeping mpg logs, you'll know the truth after about 2000 miles.
Actually tires have the least rolling resistance when they are just about out of tread. But as they also offer the least traction, it is not in your overall safety interest to run them that way. Except during fuel economy competitions perhaps?
DAS
tochatihu is offline
Old 05-15-2007, 01:51 PM   #3
Tideland Prius
Super Moderator
Tideland Prius's Avatar
Friends: 11
Here, use this.
http://www.teamswift.net/archives/tyre_bible.html
Somewhere down the middle of the page is a tyre size calculator. You'll need Javascript enabled for this. Type in the stock tyre size (175/65R14 right?) and then type in 185/65R14 into their respective boxes. There, it'll tell you the circumference, difference and speed difference.
Tideland Prius is offline
Betting on a 2001 Prius Prianista Prius and Hybrid News 5 08-15-2007 11:52 PM
2001 Prius organic_mechanic Private Sales 0 01-24-2007 11:25 AM
help me with 2001 Prius hmemar Prius Modifications 1 09-08-2006 11:56 AM
2001 Prius smokey1777 Prius Main Forum 6 04-18-2006 06:03 PM
2001 Prius Cat Converter & ECU Tiznow13 Care, Maintenance and Troubleshooting 2 11-11-2005 12:53 AM
