Prius Main Forum This is a discussion on Moving A Large TV within the Prius Main Forum forums, part of the Toyota Prius Forums category; I bought a used TV whose dimensions are 168.5 x 100.7 x 51.4 cm. Will that fit in the Prius ...
Old 06-05-2007, 05:19 PM   #1
kinghuang
I bought a used TV whose dimensions are 168.5 x 100.7 x 51.4 cm. Will that fit in the Prius with the rear seats down? Or, do I need to find a van or some other vehicle to move it? I can't seem to find any numbers on the dimensions of the cargo area, just the volume.
kinghuang is offline
Old 06-05-2007, 07:30 PM   #2
jeromep
Send a message via ICQ to jeromep Send a message via AIM to jeromep
The smartest thing to do is measure the opening of the hatch, along with the length of the hatch with the seats down from top of the hatch threshold forward. Because of the very dramatic drop from the top of the roof to the rear you have limited cargo heigth in the cargo area, but much more heigth in the passenger area.
In general spec sheets won't give you the dimensions you need for real world use.
jeromep is offline
Old 06-06-2007, 11:20 AM   #3
daniel
Cat Lovers Against the Bomb
daniel's Avatar
<div class='quotetop'>QUOTE(kinghuang @ Jun 5 2007, 02:19 PM) [snapback]456001[/snapback]</div>
Your TV is just a shade too big. Assuming no difference in dimensions from my 2004, the rear hatch opening is only 38 inches wide, 1.5 inches narrower than your TV, and although the actual length is very close, the height at the very back is too low. If the height at the back were the only issue, you could leave the hatch open a bit, but I don't think you could get it in due to the width. That's one big TV.
Caveat: I'm assuming the dimensions you gave are for a rectangular box. If those are actually maximum dimensions on an irregular shape, then it's so close that you might possibly be able to do it, but it's too close to tell without trying.
Daniel
Primary car: Zap Xebra SD: 100% electric car. 1.9 cents per mile, using electrons generated from water power. (The Prius is my gas guzzler, used when I have to travel farther than 35 miles in a day.)
-- Emma Goldman
-- Otto von Bismarck
daniel is offline
Old 06-06-2007, 01:13 PM   #4
Devil's Advocate
Holy hollow metal batman!
Your TV is way too big!
I have a 56"x56"x18 rear projection pedestal by Toshiba which I had tyo strap to a trailer to move from LA to Vegas. It looked like the conning tower of an imperial star destroyer going down the freeway. But it made it AOK!
Devil's Advocate is offline
Old 06-06-2007, 06:27 PM   #5
MarinJohn
MarinJohn's Avatar
Some types of tv's like plasma are not supposed to be laid on their side, must be transported upright.
MarinJohn is offline
Old 06-06-2007, 07:15 PM   #6
hobbit
hobbit's Avatar
Not sure of dimensions offhand, but for large/long objects you can
gain another inch and a half of effective height by unbolting the
rear seatbacks and shoving them forward slightly. [The one with the
seatbelt is easiest to leave in the car someplace, just shift it]
I had to do this for the dryer.
_H*
hobbit is offline
Old 06-06-2007, 10:05 PM   #7
SW03ES
SW03ES's Avatar
<div class='quotetop'>QUOTE(kinghuang @ Jun 5 2007, 05:19 PM) [snapback]456001[/snapback]</div>
Got a tape measure?
SW03ES is offline
Old 06-06-2007, 10:16 PM   #8
abq sfr
abq sfr's Avatar
<div class='quotetop'>QUOTE(kinghuang @ Jun 5 2007, 03:19 PM) [snapback]456001[/snapback]</div>
I moved a 37" hdtv plasma last weekend... it just barely fit, but I had to put the back seat down. Passersby at Costco were impressed it fit in the Prius. As suggested before, measure it.
abq sfr is offline
Old 06-06-2007, 11:00 PM   #9
mcbrunnhilde
Opera singin' Prius nut!
mcbrunnhilde's Avatar
I just transported a 40-gallon water heater (larger than most because it had extra insulation) WITH THE HATCH CLOSED!!!! :-)
mcbrunnhilde is offline
Old 06-07-2007, 01:02 AM   #10
BexarWolf
BexarWolf's Avatar
I dunno about a TV but I can tell you a 6'x8' fence panel won't fit.
There are times I miss my pickup. I had to strap it to the top of the Grand Cherokee and hope I didn't get enough speed to create lift. I don't have a pilot's license.
*sigh* I looked like Jed Clampet with that thing up there.
BexarWolf is offline
Large SUV sales up 6% abq sfr Prius and Hybrid News 7 05-23-2007 01:04 PM
Large drop in MPG blackprius Fuel Economy 12 06-12-2006 08:57 PM
Large frame, how will I fit? Phyte Prius Main Forum 11 11-01-2005 03:32 PM
Large Suitcases bmgoodman Prius Main Forum 6 06-13-2005 09:25 PM
