Prius Main Forum This is a discussion on Battery Pack within the Prius Main Forum forums, part of the Toyota Prius Forums category; I realize that I am under an 8 yr. warranty, but I keep my cars for more than 8 years. ...
Old 06-14-2007, 06:07 AM   #1
eberrong
I realize that I am under an 8 yr. warranty, but I keep my cars for more than 8 years. How much is a replacement battery pack for a 07 Prius? Has anyone had to have one replaced yet on an older model?
eberrong is offline
Old 06-14-2007, 08:23 AM   #2
mmoncur
Hopefully, the question won't be "how much does one cost now" but "how much will one cost 8 years from now?".
I imagine by then it will be $500 and give you twice the battery life.
I'm glad I'm not the only one who plans on keeping this Prius a good long time...
mmoncur is offline
Old 06-14-2007, 08:34 AM   #3
SomervillePrius
Send a message via AIM to SomervillePrius Send a message via Yahoo to SomervillePrius Send a message via Skype™ to SomervillePrius
I think currently the battery costs a couple of thousands to replace BUT I haven't read of anyone actually having to replace their battery yet. I think the battery could last the life of the car.
Hopefully years from now batteries will be cheaper. If nothing else a good used battery from a crashed Prius might work.
SomervillePrius is offline
Old 06-14-2007, 09:23 AM   #4
tanglefoot
tanglefoot's Avatar
The battery pack has been tested for 180,000 miles with no deterioration. Some cars have over 230,000 miles with the original battery pack. If it does start to deteriorate, it doesn't need replacing. The car just won't deliver quite as good fuel economy.
I'm planning on keeping mine forever too.
tanglefoot is offline
Old 06-14-2007, 10:24 AM   #5
jdenenberg
jdenenberg's Avatar
Send a message via Skype™ to jdenenberg
Friends: 8
<div class='quotetop'>QUOTE(eberrong @ Jun 14 2007, 06:07 AM) [snapback]461439[/snapback]</div>
First, My 2004 has 86,000 miles and the battery shows no noticeable degradation. I am not concerned about battery life since:
  1. A new battery is currently $1100 wholesale $2200 retail (down from over $3000)
  2. Salvaged batteries are currently available for $500 to $750
  3. The number of reported "failures" is quite small (about 10 have been reported on these discussion groups),predominantly in earlier designs with most due to known failure mechanisms that are unlikely to occur in a new Prius.
  4. The "second generation" Prius (2004+) babies the battery, giving it an expected long life.
    • It limits current flow to about 100 amps - well below the maximum current handling capability of the NiMh cells.
    • It keeps the State-Of-Charge (SOC) between 40% and 80% - no deep cycling is allowed.
    • If the battery temperature rises, the use of the battery is limited so as to not stress the battery.
Just as an aside, I have had to rebuild transmissions in other cars. It typically costs $2500 and in a Prius the transmission is simpler and less likely to fail (some failures in classics have been reported, change your ATF every 60,000 miles - 15,000 miles in a classic - to minimize the chance of a tranny failure).
An engine (ICE) rebuild is also expensive, but a well maintained ICE failure is unlikely to occur in a Prius as the ICE is never stressed by the computer and only runs a percentage of the time.
A car is a complex beastie and things do fail. A Prius is more complex in many ways, but less complex mechanically than most modern cars.
Always remember, it is a Toyota so drive it and enjoy.
JeffD
jdenenberg is offline
Old 06-14-2007, 10:41 AM   #6
SomervillePrius
Thanks for the insights!
Old 06-15-2007, 06:30 PM   #7
CHART
My 2004 is nearing 90K. I haven't done any maintenance except what was called for explicitly in the warrantee book. I have started wondering about the battery since I am rapidly approaching the 100K mark. So far, other than the seat and the fuel tank, I have had nothing but LOVE for this car!
CHART is offline
Old 06-15-2007, 09:05 PM   #8
mcbrunnhilde
Opera singin' Prius nut!
mcbrunnhilde's Avatar
Don't forget the battery is warranted for 150,000 miles in California and the other CARB states...it is expected to last the life of the car. Would you expect a conventional car to break down as soon as it's out of warranty? I plan on keeping mine until it drops (and I expect over 300,000 miles out of it...). Over on John's website http://john1701a.com/ there's a picture of a Classic Prius' odometer showing some 240,000(?) miles, but I don't know whose car it is. Prius taxis also pack on the miles, and are still going strong.
Pat
2004 Salsa #7/AM "Gracie"
mcbrunnhilde is offline
Old 06-15-2007, 09:34 PM   #9
john1701a
john1701a's Avatar
Package: Pioneer #3
Jessie's Prius
john1701a is online now
Old 06-15-2007, 10:21 PM   #10
mcbrunnhilde
Yup, that's the one, John!!! Thanks for posting it. :-)
WTB Prius battery pack, Good or Bad banger Private Sales 0 11-28-2007 07:52 PM
2007 battery pack jackovalltrades Prius Technical Discussion 10 04-05-2007 01:38 AM
Needed, used '01-'03 HV battery pack efusco Private Sales 2 09-16-2006 04:43 PM
Help Assemble PRIUS+ Battery Pack Fri-Mon felixkramer CA - San Francisco Bay Area 0 09-10-2004 04:37 PM
Wieght of 04 battery pack? N9IWP Prius Main Forum 19 05-30-2004 11:48 AM
