| Prius Main Forum This is a discussion on VA Clean Special Fuel Plate within the Prius Main Forum forums, part of the Toyota Prius Forums category; Those were probably existing plates and Virginia decided not to alter them for the hybrids. In California, alternate-fuel vehicles got ... |
| | #11 |
| Opera singin' Prius nut! Join Date: Jan 2004 Location: San Diego, CA
My Car: 2004 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Those were probably existing plates and Virginia decided not to alter them for the hybrids. In California, alternate-fuel vehicles got stickers just like hybrids, but they are silver and not yellow. |
| | #13 | |
| Electrical Engineer Join Date: Jan 2007 Location: Camas, WA
My Car: 2007 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(dishpan @ Jun 22 2007, 09:35 AM) [snapback]466377[/snapback]</div> Quote:
Several of the current hybrid vehicles, vehicles like the Ford Escape and the Toyota Prius, use Atkinson cycle engines in stead of the conventional Otto-cycle. See an animation of the Atkinson Cycle engine again from Matt Keveney's excellent engine animation site. http://www.keveney.com/Atkinson.html The Atkinson-cycle engine is up to 10% more efficient than a conventional four-stroke petrol "Otto" engine. The increase in efficiency comes mainly from controlling the so called pumping losses. Pumping losses are caused by the way power output from a petrol "Otto" engine is regulated. It is regulated by controlling, or rather constricting airflow to the engine. This constriction of airflow creates partial vacuum (low pressure) in the inlet manifold. Maintaining this "low pressure" in the inlet manifold wastes energy. One reason for diesel "Otto"-engines being more effective than the corresponding petrol engines is because there is no pumping loss in a diesel as power is regulated by injecting less fuel into the cylinders and not by choking the airflow to the cylinders. The pumping losses in an Atkinson cycle engine are reduced by allowing, in the compression stroke, a small amount of the fuel/air mixture to flow back from the cylinder into the induction system, without being burned, thus reducing the effective displacement of the engine. Additionally as the expansion ratio of an Atkinson cycle engine is greater than its compression ratio it takes more heat from the exhaust gas instead of pumping it into the exhaust system, thereby achieving additional efficiency. The Atkinson cycle — also called the "five-stroke cycle" (because of the backflow which is really not a cycle) — works like this: intake, backflow (partial expulsion to eliminate pumping losses), compression, expansion, and exhaust. The combustion chamber volume is adapted to maintain a constant compression ratio to avoid knock while increasing the expansion ratio to optimize efficiency.
__________________ Lightning Green McQueen, and owner Larry 2007 Pkg 5, Jan 2007 with modifications: Toyota Mudguards Feb 2007 LED Signal mirrors March 2007 Wheelskins Leather Steering Wheel March 2007 ScanGuage II, March 2007 BT Tech Stiffening Plate, March 2007 Nokian WR 195-60R-15 tires, Nov 2007 Solar Gaurd window tint, Feb 2008 Fog Lights on idependant of headlamps, Feb 2008 BT Tech Strut Tower Brace, April, 2008 | |
| | #14 | |
My Car: 2004 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(G-Man @ Jun 22 2007, 06:41 PM) [snapback]466686[/snapback]</div> Quote:
| Utah “Clean Fuel – Clean Air” Plate | SLC-UT | Prius Main Forum | 1 | 07-17-2006 01:59 PM |
| Got my Va. Clean Fuel Plate! | GreenGene | Prius Main Forum | 5 | 05-07-2006 12:17 AM |
| Tax software and clean fuel deduction | voltswagon | Prius Main Forum | 35 | 03-04-2005 04:00 PM |
| Used Prius & Clean Fuel Tax Deduction | gabriel | Prius Main Forum | 7 | 01-09-2005 10:47 PM |
| Clean Special Fuel Plates | PriusLover | Prius Main Forum | 0 | 07-29-2004 08:02 AM |
