| Prius Main Forum This is a discussion on License plate scratching paint within the Prius Main Forum forums, part of the Toyota Prius Forums category; I got home last night and found my new license late in the mailbox. I pulled the dealer frame and ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I got home last night and found my new license late in the mailbox. I pulled the dealer frame and the temp plate off and found that the plate frame had blemished the paint on the hatch, it should buff out OK, but has anyone found a way to prevent the plate from scratching? I am thinking about getting the rubber stick-on dots or the felt pads, or should I just sand/buff the rough edges and install the plate as is? The dealer frame will NOT go back on, I even had them remove the logo from the hatch. Thanks James Have had the car for less than 4 weeks, averaging 45MPG. Beats the heck out of the ~20MPG that I got in my Deville, just hard to get use to the fact that this car is 3 feet shorter. |
| Has his homepage set to PC Join Date: Mar 2005 Location: Vancouver, BC
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | I put sound deadening material on the back of the plate. It helps with the scratches. The main purpose was to stop the plate from rattling when the bass hits, but scratch prevention is a nice side effect |
| Member Join Date: Apr 2007 Location: San Diego, CA
My Car: 2007 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I used a couple pieces of foam tape attached to the back of the plate. My first thought was to get a couple of stick-on rubber 'feet' to apply to the round indents of the hatch, but I already had the foam tape. |
| Senior Member Join Date: Apr 2006 Location: Lorena, TX
My Car: 2006 Prius Package: #1 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(jamesbugman @ Jun 21 2007, 01:06 PM) [snapback]465853[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(TheJDJ @ Jun 21 2007, 03:25 PM) [snapback]465933[/snapback]</div> Quote:
- Tom | |
My Car: 2007 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I used electronics "continuous grommet", a black plastic "U" shaped product, and used black silicone to glue it around the edge of the plate. |
| ichorous liquor Join Date: Mar 2004 Location: United States
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Closed cell foam tape or gasket material *on the car*. If you apply it to the plate, dirt gets between the foam and the paint and the car gets scratched anyway. |
| front license plate | skuke | Prius Main Forum | 5 | 04-24-2007 04:33 PM |
| What does your license plate say? | zijlstra | Prius Main Forum | 16 | 04-23-2007 11:05 AM |
| My License Plate | Jon | Prius Main Forum | 28 | 06-06-2005 09:35 PM |
| COOLEST license plate ever | naterprius | Other Cars | 3 | 03-04-2005 03:26 PM |
| New License Plate on Order | charliep | Prius Main Forum | 2 | 09-21-2004 02:33 PM |
