Prius Main Forum This is a discussion on Just hit 5k, first oil change due, anything special to know for doing it myself? within the Prius Main Forum forums, part of the Toyota Prius Forums category; [quote=MickeyA @ Jun 25 2007, 11:55 AM) [snapback]467594[/snapback]</div> Used a MityVac to pump my oil out & Rhino Ramps to ...
Old 06-25-2007, 02:08 PM   #31
Swanny1172
Swanny1172's Avatar
Used a MityVac to pump my oil out & Rhino Ramps to pull off the filter.
30 minutes including prep & cleanup.
Changed out the factory oil] 1100 miles.
Surprised it was so clean on the dipstick but black as night in the MityVac.
There was some metal flakes from the wear in.
My plan is:
Use the Castrol GTX until 5k. Then will switch out to whatever synth is on sale & go 7500 OCI then.
Will get a lifetime rotation plan from NTB for $50 so I can have the tires rotated @ the same interval.
btw:
The Napa wrench (thanks to FloridaWen in a previous thread) fitted perfectly.
This is my first spin on filter & I can't believe how easy it is.
Too bad it adds waste to the environment more so than the cartridge types.
Why would you use a MityVac if you are already going to be under the car? I use a MityVac on my Mercedes, but then again, the oil filter is on top of the engine. With the Prius, I figure that I have to get under there to change the filter, so why not just drain the oil as well?
Swanny1172 is offline
Old 06-25-2007, 02:14 PM   #32
gforeman
gforeman's Avatar
<div class='quotetop'>QUOTE(Swanny1172 @ Jun 25 2007, 02:08 PM) [snapback]467663[/snapback]</div>
I would think the MityVac would not get all the oil, or am I wrong? I think I'd have to do the MityVac once and then remove the drain to see what was left.
I still think the FumotoValve is great !
gforeman is offline
Old 06-25-2007, 02:22 PM   #33
MickeyA
I spend 5 minutes under the car with attention to detail.
Plus, I don't need a big oil catch pan.
The little oil that comes out from the filter can fall into a little plastic tub I have which pours back into the mityvac.
Carry the MityVac to the local AAP to dump into their recycling bin.
No fuss & no muss. 5 Minutes under the car.
<div class='quotetop'>QUOTE(G-Man @ Jun 25 2007, 02:14 PM) [snapback]467669[/snapback]</div>
There have been many ppl who have done both & have noticed no appreciable differences in what comes out.
Also do you know for sure if all the oil has been 100% removed from all the engine's cylinders or other crevices either way?
MickeyA is offline
Old 06-25-2007, 02:24 PM   #34
gforeman
gforeman's Avatar
<div class='quotetop'>QUOTE(morpheusx @ Jun 25 2007, 09:32 AM) [snapback]467555[/snapback]</div>
I figure it this way the US manufacturers are now pushing 7500 miles for oil intervals and the oil companies are still pushing 3000 miles for oil intervals. My logical thinking is the oil companies want you to buy more oil and the car manufacturers want you to buy more cars by wearing out your car faster (good enough to get you past the warranty period but not last 150,000 - 250,000 miles.)
I have always just changed mine every 3 months anyway, I always have seemed to average about 1500 miles a month anyway.
I just sold my '96 Accord with 186k on it. Oil changes at 7,500 miles. Oil analysis done a few times. When I sold it, no oil use between changes, and a clean bill of health from the analysis.
186k changed every 7,500 = 25 oil changes * $30 using Full Synthetic AMSOIL and OEM Filters, total $750
186k changed every 3000 = 62 oil changes x $30 using the same oil and filters = $1860.
Not to mention the extra time involved.
I will stick with the Toyota reccomendation of 5K. The Accord schedule was 7,500. I will use Mobil 1 since I can get 5W-30 at Costco. 5W-20 for the Accord is harder to find.
The car was in EXCELLENT condition, and I sold it to a good friend for $2600. Never spent a dime other than regular scheduled items. Timing belt and water pump being the most expensive at 90k twice.
I hope this Prius is as reliable!
gforeman is offline
Old 06-25-2007, 02:37 PM   #35
MickeyA
[quote=G-Man @ Jun 25 2007, 02:24 PM) [snapback]467676[/snapback]</div>
Knowing what we know today esp. with Amsoil synth & dino performances, there is no need to waste synth] 3k OCI. Besides the obvious environmental waste of 37 more filters!
Anyhow: I would think a fairer comparison would be:
vs
186k changed every 3000 = 62 oil changes x $15 using the DINO oil and OEM filters = $930.
Then it comes down how to value your 37 extra 1/2 hours to spend with a dino change.
MickeyA is offline
Old 06-25-2007, 02:41 PM   #36
Swanny1172
Swanny1172's Avatar
My Mercedes takes 8 1/2 quarts of oil at each change. When I use the MityVac, that is exactly what I get out, so I know it is getting it all out. Also, I did both one time, using the MityVac and then double-checking by removing the drain plug. All that was left was a couple of drips.
Old 06-25-2007, 05:31 PM   #37
Winston
Winston's Avatar
It is amazing that mfg's still recommend 5k or even 7.5k oil changes. That is the same interval that the recommended 20 years ago. Oil today is light years better than oil was 20 years ago. The latest API SM oils are probably better than the original Mobil 1 Full Synthetic oil. GM uses a sophisticated oil life monitor. Some people go 12k miles before the monitor says to change the oil.
3k oil changes are a waste of resources. I will be going 10k with synthetic oil.
Winston is offline
Old 06-25-2007, 05:37 PM   #38
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 7
<div class='quotetop'>QUOTE(MickeyA @ Jun 25 2007, 07:55 AM) [snapback]467594[/snapback]</div>
Probably too late now, but I wish we could see a used oil analysis from your 'first fill' stuff, Mickey. Would you consider doing it next time around? Second fills would be interesting as well. Would cost you about $20.
tochatihu is offline
Old 06-25-2007, 05:49 PM   #39
Betelgeuse
Betelgeuse's Avatar
<div class='quotetop'>QUOTE(Winston @ Jun 25 2007, 04:31 PM) [snapback]467815[/snapback]</div>
Your call, but "only" changing your oil every 10K miles does give Toyota a foothold if they want to claim that you caused (potential future) engine damage by not changing your oil as often as they wanted you to.
Note that this statement shouldn't be confused with me actually thinking that it will cause damage. I just feel like changing your oil every 10K gives Toyota room to (potentially) wiggle out of warranty claims.
Betelgeuse is offline
Old 06-25-2007, 09:30 PM   #40
morpheusx
Professor Chaos
morpheusx's Avatar
<div class='quotetop'>QUOTE(Betelgeuse @ Jun 25 2007, 05:49 PM) [snapback]467824[/snapback]</div>
Plus changing oil is not expensive, and since I recycle it there is no harm to the environment as it is reused for other products. Not sure what they make with it though.
morpheusx is offline
Cnn Global Special on 10/23 & 10/24 Walker1 Fred's House of Pancakes 2 10-25-2007 05:20 PM
Special Financing? Lcruiser Prius Main Forum 1 04-22-2007 11:17 PM
Special sticker? So-Cal seasidetraveler Prius Main Forum 5 10-10-2005 07:40 PM
Mmm.. What's this Special Deal all about? n3ok318 Prius Main Forum 3 05-27-2004 01:26 PM
Special Parking... texassalsa04 Prius Main Forum 33 05-07-2004 02:15 PM
