Prius Main Forum This is a discussion on Replace 12v battery? within the Prius Main Forum forums, part of the Toyota Prius Forums category; It seems that the stock 12v battery may be a bit small in terms of the time you can run ...
Old 07-17-2007, 03:08 AM   #1
lagreca
Send a message via ICQ to lagreca Send a message via AIM to lagreca Send a message via MSN to lagreca Send a message via Yahoo to lagreca
It seems that the stock 12v battery may be a bit small in terms of the time you can run your radio, before it dies.
Is it possible to replace it with a higher ah battery?
What is the maximum size batter you can put in?
What about posts location and size?
Does anyone know of a specific battery that will replace the stock one?
lagreca is offline
Old 07-18-2007, 02:02 AM   #2
lagreca
<div align="left">While looking at other information, ran into this site:
http://www.techno-fandom.org/%7Ehobbit/cars/prius-12V/
However, I'm still wondering if anyone has had to replace their 12v battery yet, and if so, what model did they use?</div>
lagreca is offline
Old 07-18-2007, 01:26 PM   #3
David Beale
David Beale's Avatar
Just had a look at an Optima yellow top in size 51. It looks like it will just fit, but the terminals are backwards and the wrong diameter. So some work would be needed to use it. Probably doable though.
David Beale is offline
Old 07-18-2007, 02:27 PM   #4
abq sfr
abq sfr's Avatar
<div class='quotetop'>QUOTE(lagreca @ Jul 17 2007, 01:08 AM) [snapback]480113[/snapback]</div>
If I were that worried, I'd carry one of those self-contained jump start units that Costco has for around $40, it might even store under the trunk floor. Even if you replaced the stock battery with a larger capacity one that would fit in roughly the same space it would probably only run 20% longer before running down... but it would still run down eventually. I run a 50-watt ham radio transmitter off of that little battery, and am not too worried about the battery draining. As long as you have the ready light on the dash, if it you drain the 12v too low it will get charged up again anyway. Remember the 12v battery does not need to provide that much amperage... it mostly just needs enough juice to boot the computer.
abq sfr is offline
Old 07-18-2007, 02:53 PM   #5
dogfriend
Human - Animal Hybrid
dogfriend's Avatar
Friends: 7
<div class='quotetop'>QUOTE(abq sfr @ Jul 18 2007, 11:27 AM) [snapback]481054[/snapback]</div>
If I were that worried, I'd carry one of those self-contained jump start units that Costco has for around $40, it might even store under the trunk floor.[/b]
Yep, I bought one from WalMart for $35. It is a Black and Decker brand, but it is actually made by Vector and is also sold under that brand (possibly even cheaper).
I think it would fit under the deck lid, but it would have to be layed down on its side; the instructions recommend keeping it upright. I store mine on the right side of the cargo area above the 12v battery. I have it bungie corded to the cargo tie down, so it won't become a projectile, and having it visible reminds me to check the charge level once a week or so.
Another advantage is that you can use it to jump other vehicles without involving your Prius.
My friends Dingo and Digby
dogfriend is offline
Old 07-18-2007, 04:26 PM   #6
auricchio
auricchio's Avatar
Package: #8
If you're going to listen to the radio or use other accessories for a long time, just put the car into "ready" mode as if you're going to drive away. The traction battery will keep the 12v battery charged, and the ICE will start if it needs to charge the traction battery.
In most cases, the ICE will never need to start, because the traction battery will be able to keep the 12v system charged for a long time.
auricchio is offline
Old 07-19-2007, 12:01 AM   #7
9G-man
Just put your car into IGN-ON mode and you can run your radio about forever. The HV battery will discharge, but it will take a long time. Plus, the HV battery S.O.C. will be displayed on the MFD, so if it gets too low, either shutdown, or go to READY mode and let the ICE recharge it.
Don't think I'd sit around in READY mode unnecessarily, or unattended. Someone could bump the shifter and then the car could easily move.
9G-man is offline
Old 07-19-2007, 12:12 AM   #8
dogfriend
dogfriend's Avatar
Friends: 7
<div class='quotetop'>QUOTE(9G-man @ Jul 18 2007, 09:01 PM) [snapback]481387[/snapback]</div>
They have to step on the brake pedal and bump the shift lever at the same time. Otherwise it will just beep.
Old 07-19-2007, 12:51 AM   #9
auricchio
auricchio's Avatar
Package: #8
Press the brake pedal, move the shifter, and release the parking brake.
Not something that would happen accidentally: there are three separate actions, requiring two feet and one hand.
Old 07-19-2007, 08:39 AM   #10
9G-man
Does anyone recall "Unintended Acceleration". It almost put Audi out of business in the early '80's. And it required 4 seperate actions. The three you mentioned and 1 more......Stupidity.
The main point here is IGN-ON mode will accomplish what READY mode will for extended radio listening without potential for problems. And it eliminates one unnecessary ICE start cycle. The first one.
9G-man is offline
replace Key Fob Battery? Rick Grahn Prius Main Forum 21 03-17-2008 12:54 PM
Replace Battery in key warning Samsurfer Care, Maintenance and Troubleshooting 22 12-26-2007 07:27 PM
$7,000 to replace the battery?! Spoon Prius Technical Discussion 9 08-06-2007 09:48 PM
2001 Prius battery problem...replace cells? lutung Prius Technical Discussion 4 07-29-2007 12:26 PM
