Prius Main Forum This is a discussion on BlueX 28 LED Review within the Prius Main Forum forums, part of the Toyota Prius Forums category; Updated: 7/29/2007: The festoon bulb fit in the housing! Mod, can we have a separate Product Review forum? In this ...
Old 07-18-2007, 12:09 AM   #1
usbseawolf2000
Pro Efficient Technologies
usbseawolf2000's Avatar
Friends: 34
In this review, I will be presenting you with my installation and impression of BlueX LED Dome/Door/Box LIGHT with 28 white LEDs. They make many different version with 8/9/10/12/14/15/16/18/24/28/40 LEDs in Red/Green/Blue/Yellow/White colors. This review is for the 28 White LED version and it draws about 3 Watts of power. The OEM Incandescent bulb is rated at 5 Watts.
I ordered it from Dealextreme on 7/9/2007. It was shipped on 7/10/2007 and I received it on today (7/17/2007). It cost me $9.94 (no tax) and Dealextreme offered it with free shipping. The delivery took 6 business days and it came from Hong Kong. The product seems well made and I am not an expert on electronic to review it in technical detail.
The installation was extremely easy. Here are the picture I took step by step while installing.
[attachmentid=9833]
The picture was taken with the camera flash on my Prius rear seat.
[attachmentid=9839]
This picture was taken after the installation under 28 LED own light without flash. Notice the color difference and my shadow.
[attachmentid=9834]
I simply connected the festoon wire to the LED module.
[attachmentid=10248]
The festoon bulb barely fit into the housing.
[attachmentid=9836]
After the installation, this picture was taken with the camera flash.
[attachmentid=9837]
This one was taken without the camera flash.
[attachmentid=9838]
This picture shows the contrast between the LED and the street lamp. The front dome LEDs are 1 Watt Xenon bulbs from ebay.
[attachmentid=9840]
This is the view from outside showing the brightness.
I took a quick video after the installation. My rear windows are tinted with 35% Visible Light Transmission.
I am very please with this product and it is a well spend 10 bucks.
bluex-28-led-review-cimg1396.jpg  bluex-28-led-review-cimg1398.jpg  bluex-28-led-review-cimg1402.jpg  bluex-28-led-review-cimg1404.jpg  bluex-28-led-review-cimg1407.jpg
bluex-28-led-review-cimg1410.jpg  bluex-28-led-review-cimg1413.jpg  bluex-28-led-review-bluex.jpg
Prius shaped the form of future cars. Hybrid Synergy Drive is the engine of change that moved us forward.
Kyowa KR206 17" Black Chrome Lips | Sherwood Wood Dash (Birds Eye) | EV Button | Auterra Dyno Scan | Fumoto Valve (F-103) | Garmin Nuvi 250W GPS | Philips Vision Plus
usbseawolf2000 is offline
Old 07-24-2007, 12:53 AM   #2
usbseawolf2000
Friends: 34
I have not measure the power it draws yet. I have been busy adding B-Quiet Ultimate to all four doors. The LED was acting funny and as I was playing around with the switch (ON/OFF/DOOR) while having other LEDs turned on, the Dome fuse blew.
The radio, clock, MPG history, Dome lights, and Smart Key System died as a result of it. I could not even lock the car with the remote. I thought my 12-volt battery died because I had my LED lights on while finishing up the B-Quiet install. I started up the car by inserting the Smart Key into the ignition and the car turned on! I am now using the spare fuse in the box and the white tool that came in the fuse box is very helpful to pull out and insert them.
I still need to investigate what blew my 15 Amp Dome fuse and measure the power of BlueX LED module.
Old 07-28-2007, 03:03 PM   #3
godyn
godyn's Avatar
<div class='quotetop'>QUOTE(usbseawolf2000 @ Jul 24 2007, 06:53 AM) [snapback]483985[/snapback]</div>
It's a pitty the leds bluew your fuse. I was looking also for a good led replacement.
Be shure to keep the progress posted inthis post, I would like to knew :-)
S.th. else: I see you have the door leather cover.
Which ones are those? Where did you get them and what did they cost? Was it easy to install?
I'm looking for armwrest cover also.
So many questions :-)
godyn is offline
Old 07-29-2007, 05:42 PM   #4
ryanschram
ryanschram's Avatar
Package: #8
Send a message via AIM to ryanschram
let me know when you're finished with the project
ryanschram is offline
Old 07-29-2007, 06:31 PM   #5
CheepCheep
CheepCheep's Avatar
Nice mod.
Wondering whether your new LED's blew your fuse. . .
Please post the power draw when you measure it!
java script:emoticon('', 'smid_4')
CheepCheep is offline
Old 07-29-2007, 08:24 PM   #6
usbseawolf2000
Friends: 34
<div class='quotetop'>QUOTE(Godyn @ Jul 28 2007, 03:03 PM) [snapback]486743[/snapback]</div>
The fuse probably blew due to the loose connection of the festoon. When I opened it up, I found it loose. This time, I tried to install it properly and it went in! I was going to remove the end metal caps from the festoon bulb and cut (to shorten) the plastic tube. There is no need for all of that. The bulb fit in fine.
My leather door armrests are from ebay (Prius Hood). The leather for all 4 doors cost me $80 plus $5 shipping. I did not like how it was supposed to install with Velcro so I custom install them by removing the panel.
odd review, i think on the prius statultra Prius and Hybrid News 17 05-31-2007 08:51 PM
Bad review, oh wow seasidetraveler Prius Main Forum 44 10-23-2006 09:22 AM
(another) 1 year review rflagg Prius Main Forum 1 02-28-2005 10:44 AM
First Impressions / review ryecatcher Prius Main Forum 2 09-21-2004 03:10 PM
So maybe Car & Driver can do a better review than me... Danny Prius Main Forum 4 01-14-2004 06:36 PM
