| Prius Main Forum This is a discussion on Anyone out there have Smog Check readings for a Prii?? within the Prius Main Forum forums, part of the Toyota Prius Forums category; I know the Prii is now exempt from ever needing a California Smog Check, but I am curious if anyone ... |
My Car: Other Non-Hybrid Package: N/A Nominated 15 Times in 1 Post TOTM Awards: 1Friends: 0 | I know the Prii is now exempt from ever needing a California Smog Check, but I am curious if anyone out there has had a smog check done on a Prii??? The Prius is not compatible with California's Two Speed Idle or ASM tests because of vehicle design. But, apparently referee stations CAN do the checks in California. I just had our (temporary) 1996 Ford Taurus smog checked - it barely passed! Here are it’s readings: Tested for = Measured . . . Max alowed at 15mph/25mph HC (ppm) = 52/28 . . . . . 52/36 CO (%) = 0.12/0.03 . . . 0.49/0.46 NO (ppm) = 53/126 . . . 424/711 Anyone out there have readings for a Prii? Say what model year and when check was done.
__________________ My words are my word. I refuse to actively participate in any forum where my written words can/are changed by the powers that be. If you don't like what I wrote, delete it – but don't put words in my mouth that aren't mine. Good-bye. |
| Senior Member Join Date: Mar 2004 Location: Seattle, WA
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | In Washington, they won't let us take Prii in for a smog-emissions test. We're exempted. (I guess I could slip them money under the counter; I'm just not sure how to do so because of (as you say) vehicle design. |
| Senior Member Join Date: Jun 2004 Location: Denver CO
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Colorado is the same as Washington... I think it maybe because the smog check, in Colorado is done with a dynamometer... and with the ICE being intermittent they can't get a good reading... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I just sold my Impreza for my Prius that I picked up today. My Impreza was exempt from the Rhode Island emission testing because it was 4 wheel drive and the testing machines couldn't handle 4wd. Plus, it was felt that Subaru's would probably always pass due to thier past history. I have no idea if the Prius is exempt in RI. But it would be stupid if it were not. It would be a waste of everyones time. I do hope that someone responds in this thread about actual numbers for the Prius so we can compare to the Taurus above. That would be cool. It may just be that our Prii won't register on their machines due to not be calibrated low enough. LOL |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Thanks Dean...I have ordered it.. this one is a paper plate I found on eBay.. looks real... haven't put it on the car.. hope the state gets me the real ones before Toyota catches up on the waiting lists.. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | the reading for the wife's old 2k1 Prius, after 2 1/2 hours in the test station and finally after 3 kick outs of the test computer and a manager over ride and his comment about "these damn cars don't need to be tested" produced these results. Only on the driving test as it was the idle test that kicked out, how do you get results when it dont' idle. HC reading .0513 max allowable .3700 CO reading 1.0064 max allowable 6.2100 NOx reading .0031 max allowable .9300 these readings are in grams/per Kilometer this was for a car with 43,000KMs on it, under 30,000 miles. The guy behind her in the Jeep who had to let her in front of him because she was in the wrong lane to be tested, must have been P***ed about it. There is word going around that the Prius will be exempt in the next year or so. The Yellow Cab owner told her just to leave the A/C on and that will give them a idle test and your out in 15 minutes, oh ya sure, after a 2 1/2 hour test she find this out. I remember she burnt supper as well that day, some day's are diamonds and some are stones.
__________________ You can quote me on this, People who drive vehicles that idle at a traffic light, are idiots. mine 2k3 avg. 5.36 for 46,915Km Best tank 4.4L per 100K 64.2 Imperial 53.4 U.S. gallon, MiniScanner, SilverStars, block heater, winter lips, in as of Oct 15, out on April 25. In again on Sept. 21st. her's 2k4 "B" avg. 6.01 for 42,317 Km Best tank 4.02L per 100K, CAN-view with OBD11 module and flashloader, SilverStars, 06 Chrome grill bar, Michelin HydroEdge, upper and lower grill blocker,upper out as of April 7, lower out on April 28. In again on Sept 21st. |
My Car: Other Non-Hybrid Package: N/A Nominated 15 Times in 1 Post TOTM Awards: 1Friends: 0 | Quote:
I had heard of a Prii Smog Check done in the Los Angeles area where the tech was having a hard time getting a proper reading. He even did the air conditioner on thing. He finally figured out that the car was reading cleaner than ambient air, so he zeroed out the machine with the probe in the Prii tail pipe, then pulled the probe out to read the ambient smog. Anybody remember reading/hearing about it? Any links so this isn’t just hearsay? | |
| Senior Member Join Date: Aug 2004 Location: MS Gulf Coast
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
Why doesn't the California EPA just buy 100,000 Prii, position them around the State, and run them 24/7. It would clean up the Smog problem in a few days, well maybe a month. :mrgreen: | |
| CA smog check for 2006 Prius | whodat | Prius Technical Discussion | 6 | 07-20-2006 02:59 PM |
| California Smog Check? | WeHoPriusGuy | Prius Main Forum | 2 | 01-12-2006 08:09 PM |
| Annual smog check | Heikki | Care, Maintenance and Troubleshooting | 15 | 03-25-2005 09:11 AM |
| California smog check? | raybo | Prius Main Forum | 3 | 12-08-2004 03:07 PM |
| smog check - WHERE in O.C. California | lawrenceingalls | Prius Main Forum | 3 | 05-23-2004 10:06 PM |
