| Prius Main Forum This is a discussion on Just drove mine home! within the Prius Main Forum forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(halpey1 @ Sep 8 2007, 06:04 PM) [snapback]509204[/snapback]</div> I did figure out how to get my phone to work ... |
| | #11 | |
| Member Join Date: Aug 2006 Location: Potomac Falls, VA
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(halpey1 @ Sep 8 2007, 06:04 PM) [snapback]509204[/snapback]</div> Quote:
1. Power on the car to IG-ON or READY. IG-ON will do for this purpose. 2. Using the Trip/ODO button, set the Trip/ODO display to ODO (not Trip A or Trip 3. Power off the car. 4. Now power the car to READY (brake on). This is required so that step 6 works correctly. 5. Within 6 seconds of powering on, press and hold the Trip/ODO button for 10 seconds or more (there is no indication... just count) 6. WHILE STILL HOLDING ODO *after* the 10 seconds, shift the "gear" selector to R, then press the P button. Now release the Trip/ODO button. 7. If the last step was successful, "b on" or "b off" should be displayed in the location where the Trip Odometer or Odometer is normally displayed (front dash area). "b on" is beep on (default), and "b off" is beep off. 8. Press Trip/ODO to toggle the mode. 9. Now power the car off to exit the toggle mode. 10. Power the car on to READY and confirm the reverse beep status by shifting to R. The beep should not be audible if "b off" was selected, and should be audible if "b on" was selected.. Note: The Repair manual page states that if the the 12v battery is disconnected, the beep will reset to the default of on, and this procedure will need to be performed again - I have confirmed this to be true!. The repair manual also is not clear that Trip/ODO should remain depressed while shifting. Additional Note: The driver and passenger seatbelt reminder chime can be disabled or enabled (respectively, defaults are driver on and passenger off) using similar steps. Instead of shifting from P to R to P in step 6, simply buckle then unbuckle the appropriate seatbelt while continuing to depress the Trip/ODO button. Might want a helper for this one!
__________________ John C. Potomac Falls, VA 2007 Package #6, Magnetic Gray | |
| Just drove Home | ryancarlin | SC - South Carolina | 9 | 08-11-2008 04:19 AM |
| Drove the new Jetta TDI | Tideland Prius | Other Cars | 8 | 10-23-2006 11:37 PM |
| Drove home my 2007 Touring Edition today | cbc | Prius Main Forum | 5 | 10-02-2006 01:08 AM |
| Drove my 06 Prius back home yesterday! | coolfire74 | Prius Main Forum | 5 | 01-06-2006 03:06 PM |
| I drove a Camry | daniel | Prius Main Forum | 3 | 12-18-2004 11:13 AM |
