| Prius Main Forum This is a discussion on Advice for owning and driving a new Prius within the Prius Main Forum forums, part of the Toyota Prius Forums category; The egg-under-the-foot philosophy is not universal. Some folks, including the guru of Prius, john1701a, advocate accelerating right up to speed, ... |
| | #11 |
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The egg-under-the-foot philosophy is not universal. Some folks, including the guru of Prius, john1701a, advocate accelerating right up to speed, and then easing off, much more like you'd drive any other car. Don't floor it, but don't baby it, either. In other words, JUST DRIVE IT! And try not to stare at the screen. |
| | #12 | |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
| | #13 |
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | i recommend paint sealer and fabric sealer. also keep in mind that you can probably get a better deal than what your dealer can offer you by shopping around. my sister works for Ford and she says the soundguard/undercoat is a rip off. other than that, you will find that the Prius can and does drive like any other car... it simply does it waaay cooler! |
| | #14 | |
it's a cool feeling when i get it going that way, sort of like being one with the car! ICE on, ICE off... | |
| | #15 | |
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
However I have made two observations: 1. that the car is reluctant to charge the battery above 6 bars (it will do it, but it prefers not to), and 2. that at much slower speeds (below 20 or so) the mileage is usually very poor. So I strive to use electric (via the EV switch if necessary) any time the SOC is above half and I am travelling slowly. A good example is when road work slows traffic way down or where there are lots of stops. If the SOC is lower, I figure the car will strive to recharge it, so the engine output will not be wasted.
__________________ Daniel ---------------------- Primary car: Zap Xebra SD: 100% electric car. 1.9 cents per mile, using electrons generated from water power. (The Prius is my gas guzzler, used when I have to travel farther than 35 miles in a day.) "If voting changed anything, they'd make it illegal." -- Emma Goldman "Anyone who has ever looked into the glazed eyes of a soldier dying on the battlefield will think long and hard before starting a war." -- Otto von Bismarck | |
| | #16 | |
My Car: 2004 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
1. Reduces the amount of EV distance at speed due to to the laws of physics - it takes more energy to get an object moving than to keep it moving. The kid on the razor scooter thinks you want to race 2. Uses the ICE to get the car to speed and may charge the battery but does not deplete it. This leaves the highest SOC possible for EV distance 3. Gets you up to speed faster but you'll still have more EV distance available than 1 4. You and the Hummer next to you are getting the same mileage I think if conditions allow, number 2 works best for mpg. It isn't the "egg under the pedal" method but it is approaching it because just a little more pressure and you'll be in number 3. None of this matters in the first 5 minutes as the ICE will run anyway. Of course this assumes flat terrain and no traffic. If you happen to know that you'll be on the interstate in 1/2 mile and you can reasonably do EV mode to get there, number 1 can make sense. This is why some people want the EV button. They do sometimes know better than the computer :-)
__________________ Bruce Mine: Driftwood '04 BC 24 Sept 2004 - added: mudflaps, door edge guards, side panel mouldings, Coastal Tech EV switch, Hakkapeliitta RSi tires, WeatherTech window deflectors. Last tank - 11 Nov '08: 551.6 miles - MFD MPG: 52.4 Actuals Lifetime: 78923.8 miles, 48.75 MPG. Wife's: Barcelona '06 #7 May 2006 - added: front mudflaps, Coastal Tech EV switch, Hakkapeliitta RSi tires. Last tank - 25 Aug '08: 360.5 miles - MFD MPG: 50.0 Actuals Lifetime: 25,896.4 miles, 45.78 MPG. | |
| | #17 |
| nacreous lacquer Join Date: Mar 2004 Location: United States
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | And, of course, after you get home read the entire manual. There is some important stuff that's not obvious (like towing, jumpstarts, storage for more than two weeks). |
| | #18 |
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | no matter what the operation of the car, the best mpg will occur when the least amount of energy is expended. that means the least energetic acceleration. all these posts about people who accelerate rapidly to speed then ease off and coast will not be better than accelerating slowly to speed. the amount of energy to accelerate is not linear. the energy required to accelerate is exponentially proportional to the rate of acceleration. therefore the slowest rate of acceleration will expend the least amount of energy. |
| | #19 |
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Dave: you are ignoring the entire question of the internal efficiency of the ICE, PSD, and HSD. You are looking at driveshaft-to-wheels efficiency, rather than tank-to-wheels efficiency, which is the real measure we are all interested in. |
| Top 10 reasons for owning a Prius | faxman | Fuel Economy | 21 | 07-31-2007 05:31 AM |
| How realistic are the benifits of owning a Prius? | Rogerfan | Prius Main Forum | 39 | 07-20-2007 01:50 AM |
| Test Driving Used 2005 Prius tomorrow - advice? | avmdog | Dealers & Pricing | 2 | 06-03-2007 08:08 PM |
| Does driving a prius or hybrid absolve you of the sins of driving through a drive-thru? | burritos | Fuel Economy | 22 | 08-27-2006 04:15 PM |
| More on Prius Owning Celebrities | Tempus | Prius Main Forum | 0 | 05-05-2004 08:07 AM |
