| Prius Main Forum This is a discussion on Does the A/C reduce mileage? within the Prius Main Forum forums, part of the Toyota Prius Forums category; Anyone who thinks the drop in MPG is significant with the A/C on and is bothered by it, I recommend ... |
| | #21 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Anyone who thinks the drop in MPG is significant with the A/C on and is bothered by it, I recommend getting treated for OCD. Get treated before it's too late, please!!! |
| | #22 | |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(hyo silver @ Oct 4 2007, 06:50 PM) [snapback]521502[/snapback]</div> Quote:
Dave M. | |
| | #23 | ||
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | <div class='quotetop'>QUOTE(Bob64 @ Oct 5 2007, 08:06 AM) [snapback]521666[/snapback]</div> Quote:
Also interesting to note that the DOE study found a big hit on the '01 Prii they tested, as I recall about 10mpg with AC on! I believe the '01's used a traditional belt driven compressor didn't they? Seems like the '04+ electrical compressor is a big improvement with regards to efficiency! <div class='quotetop'>QUOTE(dmckinstry @ Oct 5 2007, 01:12 PM) [snapback]521862[/snapback]</div> Quote:
Rob | ||
| | #24 | |
| A young senior member Join Date: Mar 2006 Location: Chicagoland, IL USA, Earth
My Car: 2006 Prius Package: #1 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | <div class='quotetop'>QUOTE(David Beale @ Oct 5 2007, 11:28 AM) [snapback]521806[/snapback]</div> Quote:
__________________ "We must be the change we seek" - Gandhi | |
| | #25 |
| Senior Member Join Date: May 2007 Location: Phoenix, AZ
My Car: 2007 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I think the A/C drain varies a lot depending on how strong it's running. I did seem to notice a drop when it was 115F here and the A/C was running full power pretty much all the time. Now that it's cooler and it runs less (or not at all), I seem to be getting better mileage. |
| | #26 | |
| Senior Member Join Date: Feb 2006 Location: N/W of Chicago
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | <div class='quotetop'>QUOTE(PriusOwner004 @ Oct 5 2007, 12:58 PM) [snapback]521853[/snapback]</div> Quote:
| | #27 |
| Senior Member Join Date: Nov 2005 Location: Madison, WI, USA
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | What I've been able to see since I got my CAN-View is that the biggest draw from using the AC is (a) when it runs on high when you first startup in order to bring the cabin down towards the setpoint and ( The AC on full-blast is easily 12-15 amps coming out of your battery. That's pretty darn significant, especially when you startup and pull 30-50 amps in stage-1 warmup to get yourself to even 25 MPH. Advice point #1: Don't run the AC until stage 1 is complete. Open your windows and let the wind take out the really hot air that may have gathered inside while you were parked in the sun. Corollary: park in the shade and crack open a window or two -- it really helps! Advice point #2: Don't run the AC when your engine is stopped for more than a brief while. Turning off the AC for the 10-45 seconds you're at a stoplight will really help not bring down the SOC of your battery. If you've been running the AC for a while already, it won't get much hotter in your car during that time. This also goes for long stealth glides. At 40 MPH, you're pulling at least 5.5 amps as it is. Don't pull another 10 if you can help it -- just turn off the AC for that 30 seconds. Then turn it on when the engine is running (i.e. while you pulse back up). This may sound a bit ridiculous -- but on a 35 mile mixed city/highway trip that I do pretty often, my highest MPG record was when I had the AC on and used this method! Once the AC has brought the cabin down to a reasonable level and it cuts back on the amount of power the compressor consumes (a big advantage of the Prius system), thing really aren't that bad. This is why there isn't a huge hit on long distance highway driving, and there is an enormous hit on really short city driving. Once I moved such that I was 3 miles away from work, I stopped using the AC altogether for my commute, because it would bring my trip MPG down at least 20%. I'm not even kidding... Anyway, the moral of the story: Use the AC judiciously. Having the CAN-View really helped me understand how to use an energy hog more wisely without a big sacrifice
__________________ Loved since 4/15/06: 2006 Prius, Pkg. 7, Barcelona Red/Gray Coastal EV Mod V4 CAN-View (so awesome!) Check out the hybrid car project I worked on in college! Best tank: 711 miles, 66.1 MPG! |
| | #28 | |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 24 | <div class='quotetop'>QUOTE(iluvmacs @ Oct 5 2007, 09:13 PM) [snapback]522045[/snapback]</div> Quote:
I prefer to allow stage 1 to complete, and ideally get into stage 4, with the windows down to allow the inside and outside temps equalize. This is usually quite doable since you rarely have to jump immediately on the highway. I then set the AC temp (before turning it on) to something like 80 or 82...turn it on and put up the windows. That way it runs at a moderate level, cools the temp to 80. Then I'll bump the temp setting down 1 or 2 degrees more and the AC will continue to run moderately until the temp has stabilized. I find that the AC is MUCH more aggressive if the set temp is below 80. | |
| How much does a bike rack reduce your MPG? | burritos | Fuel Economy | 8 | 03-04-2007 12:39 PM |
| HOV stickers reduce as mileage? | curtissac | Fuel Economy | 9 | 10-08-2006 12:33 AM |
| Does a passenger greatly reduce overall MPG's? | Soylent | Fuel Economy | 16 | 09-02-2006 06:55 PM |
| EPA change would reduce mileage shown on stickers | Areometer | Fuel Economy | 5 | 01-24-2006 02:46 AM |
| Scratched Plastic -- any way to fix/reduce? | JShorr | Care, Maintenance and Troubleshooting | 1 | 07-27-2005 12:59 AM |
