| Prius Main Forum This is a discussion on Three unrelated questions within the Prius Main Forum forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(orenf @ Oct 5 2007, 02:31 PM) [snapback]521947[/snapback]</div> Hi, Here are three unrelated questions - answers/comments are welcome. 1. ... |
| | #11 | |
| Taxi! Join Date: Jan 2006 Location: Burnaby B.C
My Car: 2004 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(orenf @ Oct 5 2007, 02:31 PM) [snapback]521947[/snapback]</div> Quote:
| | #12 | |
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 10 | <div class='quotetop'>QUOTE(9G-man @ Oct 6 2007, 03:26 PM) [snapback]522255[/snapback]</div> Quote:
| | #13 | ||
<div class='quotetop'>QUOTE(darelldd @ Oct 6 2007, 07:03 PM) [snapback]522270[/snapback]</div> Quote:
And if you get an EV switch you can really see that electric power is highly variable with accelerator pedal input | ||
| | #14 |
My Car: 2007 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | 1. The electric motors work the same as the gas one. The harder you press on the accelerator, the more electricity you use. They are electronically controlled three phase motor/generators. If you press hard enough, whether you are in "EV mode" or not, the engine will start. The reason is the system has to protect the battery. The electric motors can generate more power than the Prius uses, but the battery cannot deliver that much current safely (for battery life). So the engine is started to deliver some of the current being demanded and to provide direct propulsion as well. 2. The engine must spin when you go faster than 43 MPH/66 kmPH to avoid over-spinning MG1. It is spun up by MG2 to about 950 RPM, with no fuel being injected. Below the above speed it is allowed to stop. If you take your foot off the accelerator the system goes to "engine braking simulation regeneration". That is, it regenerates enough to cause as much braking as the Toyota engineers thought an engine would under similar circumstances in a "normal" car. To see this, use the flash program available in the sticky thread under Prius Technical:- http://priuschat.com/Introduction-to-Prius...low-t30286.html With this you can vary the engine speed, vehicle speed, etc. and see the effect on the various components. 3. I have no experience with the Civic Hybrid, but from reading the forums, the latest version should work very much like the Prius.
| European Prius 2007 Questions, questions | montecarlomonaco | Audio and Electronics | 0 | 10-25-2007 05:18 PM |
| 08 tax questions | Steven58 | Prius Tax Credit Discussion | 10 | 10-19-2007 07:17 PM |
| two questions | SSimon | Care, Maintenance and Troubleshooting | 8 | 09-09-2006 10:26 PM |
| Questions before I buy | Tosh | PriusChat Website Questions | 6 | 08-26-2006 05:03 PM |
| Okay so here are my first few questions... | StarBrite310 | Prius Main Forum | 5 | 01-24-2006 02:19 PM |
