Prius Main Forum This is a discussion on $200+ for 2003 Prius starter battery? within the Prius Main Forum forums, part of the Toyota Prius Forums category; Wow, my service department says the 2003 Prius has two types of starter battery. Replacing one would be just over ...
Old 10-25-2007, 01:44 PM   #1
gene4655
Wow, my service department says the 2003 Prius has two types of starter battery. Replacing one would be just over $200. Replacing the other would be around $240. Can this be right? Anybody with other suggestions of what would work as well?
gene4655 is offline
Old 10-25-2007, 02:28 PM   #2
skguh
skguh's Avatar
<div class='quotetop'>QUOTE(gene4655 @ Oct 25 2007, 12:44 PM) [snapback]530336[/snapback]</div>
Gold-Duralast / Battery
for a 2004 Toyota Prius
About this product:
Part Number: 51R-DLG
Weight: 27.7 lbs.
Warranty: 8 YR
Note: *** 500 cold cranking Amps (625 cranking Amps) *** (Battery is vented to outside of vehicle) -> 3 years free replacement <-
Pricing:
Unit Price: $79.99
*Core Value: $12.00
Total Price: $91.99
skguh is offline
Old 10-25-2007, 02:47 PM   #3
Prius Limo
<div class='quotetop'>QUOTE(gene4655 @ Oct 25 2007, 11:44 AM) [snapback]530336[/snapback]</div>
I am not sure about the 2003. It sounds like the electrical system differs from the 04-08? Your figures are so low, you must be referring to the low voltage battery(s)? The 2004-08 12 volt battery is basically the same as the Mazda Miata's. There is a good chance the 03 Prius can use a similar sealed and vented battery. I think the Miata battery lists for around $65.
Prius Limo is offline
starter battery problem newblue07 Care, Maintenance and Troubleshooting 24 10-05-2007 12:05 AM
Prius 12V Starter Battery dhoward Prius Main Forum 7 06-04-2007 12:31 PM
Prius Remote Car Starter vinnysca Prius Modifications 1 02-07-2007 09:03 PM
Prius starter motor tochatihu Prius Technical Discussion 18 11-03-2006 09:00 PM
Is the Prius starter different from regular starters? BoosPrius Prius Main Forum 6 04-29-2006 11:05 AM
