| Prius Main Forum This is a discussion on Photo of blocked front Grill. within the Prius Main Forum forums, part of the Toyota Prius Forums category; Can someone post a photo of their block grill ? I would like to see how you use the blocking ... |
| Senior Member Join Date: Jun 2006
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Can someone post a photo of their block grill ? I would like to see how you use the blocking material to block out the cold. Thanks FishHawk |
My Car: 2004 Prius Package: Pioneer #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | There are 5 photos on this page . |
| Ruler of Omicron Persei 8 Join Date: May 2004 Location: Far-North Chicagoland
My Car: 2004 Prius Package: #9 Nominated 4 Times in 2 Posts TOTM Awards: 0 Friends: 16 | . . . and a whole discussion complete with pictures here First Morning with a Blocked Grill |
| Member Join Date: Mar 2007 Location: New York
My Car: 2007 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I have to wash my car then take pictures. I just installed it for the first time on Monday, 1/14. I used 3/4" gray pipe insulation, opened it, and mounted it behind the upper grill using zip ties. For the lower grille, I used gutter guard from Home Depot. Not the fence type; the plastic that is solid except for some small slots. Again, I used zip ties and it is behind the grill. Unfortunately I only had white lying around the garage, but it does come in brown also. It isn't nearly as noticeable. |
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | You should see mine, using a neon green pool noodle!!! I'm too embarrased to even post a pic. But hey, it was free, and my son is too young to notice his pool noodle is ~2ft shorter than it was Rob Last edited by miscrms; 01-17-2008 at 06:53 PM. |
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Quote:
My Car: 2007 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
| Michigan Member Join Date: Mar 2007 Location: South Lyon, Michigan
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Here are 2 more photos. Bought 4, 6' tubes (1") for a total cost of $3.50; each tube cut in half. No zip ties used and they have not budged. Enjoy |
