| Prius Main Forum This is a discussion on Exceeding Load Limits within the Prius Main Forum forums, part of the Toyota Prius Forums category; Hello. I recently had to drive about 125 miles with 2 passengers and myself. I'm figuring the weight of each ... |
| Marvin Join Date: Jul 2007 Location: NY - Long Island
My Car: 2007 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hello. I recently had to drive about 125 miles with 2 passengers and myself. I'm figuring the weight of each occupant at 200 lbs. So that's 600 lbs. Plus 4 suitcases weighing a total of 200 lbs or over. Grand total - 800 lbs. So that was pretty close to the load limit of 810 lbs. But my question is: Would you say manufacturers figure the weight limit on the conservative side? And also I'm not always driving at the load limit. Just once in a while. So I guess everything in moderation is the key Thanks - Marvin |
| Retired Join Date: Feb 2007 Location: Macungie, Pa
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | I would say most manufacturers are conserative. Look at the airlines, they are very conserative, especially in the width of their seats. But all vehicles have a gross vehicle weight that should not be exceeded. A half ton pick-up can probably haul a ton, but the springs and chassis are not up to the loading or the brakes for that matter. I am sure that the manufacturers have a safety factor of some amount over the published limits. |
| Junior Member Join Date: Dec 2007 Location: Columbus, Ohio, USA
My Car: 2008 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Also I'm wondering how choice of tire size factors into the weight limit. Will putting on higher load index tires and/or increasing tire pressure increase the amount of weight you can carry? Or is some other part of the Prius suspension the limiting factor in the equation? |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | It's said that the tires are what limits the load most. there was an article on this recently. Most cars are fitted with tires that can handle up to the cars "limit" and not much more. this allowes for a soft ride. If you switch out for tires with a higher rating, you'll feel a little safer. You'll know when you start to get near the suspensions limits. it will start maxing out.. hitting really hard on bumps. I've hauled enough lumber and concrete inside my prius to exceed the limit... i've done this about 3 or 4 times. no problems.. no changes.. same shitty 04 suspension.
__________________ Silver 9 as of June 12th '04 (over 101k Miles now) Decals, Mud Flaps, BT Tech Rear Brace, coastaletech 2" receiver hitch, and 215/45/17 tires. |
| Senior Member Join Date: Sep 2005 Location: San Jose, CA
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
The max load should GVWR minus curb weight. Curb weight already includes a full load of fuel per Curb weight - Wikipedia, the free encyclopedia and some other places I looked. So, you shouldn't be counting fuel as part of the 810 lbs. | |
My Car: 2004 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 17 | Quote:
My Car: 2005 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | i drove the prius 1200 miles with far more than 800 lbs, we were moving and carried 5 boxes with 300 lbs each, plus two desktop computers, riding with a 40 rear 44 front pressures. |
| Senior Member Join Date: May 2007 Location: SF Bay Area, California
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I think one important issue with the load limits of a vehicle is the driving dynamics, ie handling. The Prius will handle much, much different with 800lbs than with just a 180lb driver. Stopping distance will increase, and it will handle much worse. So, when driving a fully loaded vehicle, make sure you drive more conservatively. |
Marvin | |
