| Prius Main Forum This is a discussion on Red Triangle/Dealer Refusing to Honor Hybrid Warranty? within the Prius Main Forum forums, part of the Toyota Prius Forums category; Also interesting, from the prius FAQ: 13. Can Prius run on electricity when it runs out of gas?No. Though Prius ... |
| | #111 |
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | Also interesting, from the prius FAQ: 13. Can Prius run on electricity when it runs out of gas?No. Though Prius can operate in electric-only mode when gasoline is in the tank, it is not designed to run without gasoline. Doing so could cause severe damage to the hybrid system, so drivers should be sure to keep gas in the tank at all times.Toyota.com : Vehicles : Prius : Frequently Asked Questions Rob |
| | #112 | |
| Senior Member Join Date: May 2007 Location: SF Bay Area, California
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
Changing the battery does seem simpler than changing the tranny. The story took long enough to evolve that I don't think the OP is a troll. Of course, I could be wrong, but I think he is real. Based on the description of his problems, I assumed he had some electrical insulation failure on the motors. As mentioned by MSCRMS they are part of the tranny and would not make a lot of noises. All in all these failures seem related to excessive heat. Excessive heat will fry your battery, and excessive heat will cause the motor insulation to fail. This is just a guess based on the type of failures he saw. | |
| | #113 | |
| Member Join Date: Dec 2007 Location: Miami Fl
My Car: 2004 Prius Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
........... I was talking about the guy in the toyota dealer.... toyota guy did not have a fax to send me the diagnostics... took me a while to understand this response.... anyways, no man, Im not a troll .... I wish!!! cheaper that way... and yeah... reading around.. it seems that the transmission is indeed the problem.... Damn!!! that is bad indeed.... | |
| | #114 |
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | You might want to give Steve a call at the site below. He specializes in used Prius parts and rebuilds. A number of folks on the list (myself included) have bought cars and parts from him with good luck. autobeyours salvage and rebuildable cars Rob |
