Prius Main Forum This is a discussion on OMG 2008 Prius screeching and grinding metal!!!! within the Prius Main Forum forums, part of the Toyota Prius Forums category; I've had that happen to many different vehicles, though oddly enough not to my Prius ... yet. If you drive ...
Old 03-08-2008, 12:20 PM   #11
jayman
Default Re: OMG 2008 Prius screeching and grinding metal!!!!
I've had that happen to many different vehicles, though oddly enough not to my Prius ... yet. If you drive on a gravel road for any distance, that can happen in summer
jayman is offline
Old 03-08-2008, 12:51 PM   #12
DaveinOlyWA
Opps !! I Did it Again!!
DaveinOlyWA's Avatar
Friends: 5
same thing happened to me EXCEPT i was driving POS and caught a piece of metal from a truck hauling construction debris (we think) well it squealed about 15 seconds and caught and it stopped my car in its tracks breaking the u-joint on the drive line in the process. my neck snapped, and after that i basically had so much physical problems i had to walk away from the job i had working in a paper mill two years later and get a desk job (best thing that ever happened to me!! woulda been too stubborn and too stupid to have done it on my own)
woulda been nice to have someone else pay for it besides me but could not prove anything... but im ok now and much happier
a rock is not hard enough to do that... and yes it does sound scary.
My 2006: Last tank 463.1 miles @49.2 pump (49.4 computer) 4.22 cpm
winter mpg 50.70 summer mpg 54.59
lifetime: 33,038.3 miles 52.79 mpg pump (54.04 mpg computer) 5.74 cpm
My 2007 Zenn Driven 5945 miles, 2.01 cpm/ 105 mpg (at $2.05/gal), 4.04 miles/ Kwh
Savings over my Prius $302.66 The Corolla...573.26
The REAL SAVINGS from not driving Corolla 657.39 +Prius= 958.18 (excludes maintenance costs...would be unfair to ICE vehicles)
DaveinOlyWA is offline
Old 03-08-2008, 01:15 PM   #13
V8Cobrakid
some guy...
Send a message via AIM to V8Cobrakid Send a message via Yahoo to V8Cobrakid Send a message via Skype™ to V8Cobrakid
Friends: 5
my only experiance with this is a small stone in the disk brakes. *shrug*
V8Cobrakid is offline
Old 03-08-2008, 09:03 PM   #14
Twickle Purple
Twickle Purple's Avatar
Man, that's a tough break. You came out okay which is great. I had no idea the crap on the road would get in and create the scenario with the brake.
There's a lot of debris on the roads where I live and I've had dozens of cars and driven for 30 years -- never had I experienced this. And your post shows how flukey this is.
Twickle Purple is offline
Old 03-09-2008, 08:25 PM   #15
DaveinOlyWA
Friends: 5
ya, the physical issues i had actually cleared up for the most part over time. granted this was 15 years ago... what made it so bad is that it all happened when i was only moving about 25 mph... but with absolutely no warning at all as to what was gonna happen, i was not braced for it or nothing...
Old 07-28-2008, 08:39 PM   #16
tommyzed
Hi - I don't own a Prius (a Honda Civic, to be honest), but I found this thread on a google search and I believe it fits my exact problem. I was off-roading in the Redwood National Forest (Fern Canyon) and on my way back to SF, I noticed an intermittent screeching coming from the front right tire. It sounded like metal on metal and I was pretty worried... however, upon inspection, I could see nothing wrong and I made it home OK.
Today, I noticed it starting again and so I decided to pop off the tire. Inspecting the rotor, I see a small stone-sized object between the shield and the inner disk. I tried to dislodge it, but I didn't have anything slim enough to slip through to hit the stone.
So, my question - before I stick a knife or a wire hanger up there to dislodge the stone, are there any electrical concerns I should have? Is it possible to shock/electrocute myself? I assume not since it's all metal and I can touch the rotor without problems, but I figure I should ask in case it's best to just pay a "professional" to do this easy, easy fix. (the lowest quote I got was $35).
Thanks,
tom
tommyzed is offline
Old 07-28-2008, 09:51 PM   #17
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 7
tommyZ I see no problem (electrical or otherwise) with removing the stone with knife, wire etc. Electricity does not go there. If you happen to slash the hydaulic fluid line, that would not be good. if you don't mind paying the nice man $35, that would be fine also.
tochatihu is offline
Old 07-29-2008, 12:47 AM   #18
DaveinOlyWA
Friends: 5
save yourself the money, if you can change a tire, you will have no issues getting the rock out...btw, removal of tire is not necessary.
Old 07-29-2008, 07:56 AM   #19
ChapmanF
My Car: 2001 Prius
Nominated 6 Times in 1 Post
Happened to me years ago in a Mazda 323, driving in the city. Really unnerving sound. I turned right around back to the parking garage at work and jacked up the front. It was no trouble to pin down which side the trouble was on, because just turning the tire slowly by hand sounded like I was killing a cat. I probably overreacted and removed the whole rotor and hub and looked at the bearings. I never did spot whatever chunk of grot was responsible, which probably dropped out unnoticed while I was taking stuff apart, but it was all nice and quiet again on reassembly....
-Chap
ChapmanF is offline
Old 07-29-2008, 05:23 PM   #20
tommyzed
yay! I took off the tire (can't reach it otherwise), slipped a normal butter knife in between the guard and the plate to open up the gap a bit more... and voila! Little stone pops out! No more screeching, no more worries.
Thanks so much Prius People!
tommyzed is offline
