Prius Main Forum This is a discussion on Can't get back over 50 MPG - driving me crazy within the Prius Main Forum forums, part of the Toyota Prius Forums category; Hello All, I know you will probably tell me I'm obsessing and you will probably be correct, but ever since ...
Old 04-14-2008, 07:25 PM   #1
saminjax
saminjax's Avatar
Default Can't get back over 50 MPG - driving me crazy
Hello All,
I know you will probably tell me I'm obsessing and you will probably be correct, but ever since my stupid trip a week and a half ago, I've been around 48-49 MPGs. I was averaging 52 and I can't stand being below 50. Really. It's bugging me. No matter what I do, it persists at 48.something or 49. If it's the hargin, flargin, shlargin ethanol gas, I can't wait until it is gone. I am just over a quarter of a tank, so it is almost time to fill up. I hope that is what it is. I've adjusted the tire pressure (it had dropped a tad), but that did not get me back up to my pre-trip average.
I do actually have a few questions, too. I do very well with 30-40 mph driving because I can stealth/pulse & glide. Speeds above 45 mpg are more challenging, as far as gas mileage is concerned. I tried the stealth driving techniques provided here, but I am far from mastering them. Seems like the speed drops so fast that it isn't efficient because I have to turn around and hit the gas to get back up to the speed at which I want to stay. Not a comfortable way to drive, either(up...down...up...down). On my trip, I tried to stealth some, but ended up just settling for between 45-50 mpg driving - all ICE, except for a little coasting here and there. What is the best, most efficient way to drive above 45? What is the best MPG I can expect at those speeds? (It's probably 48 mpg...hee hee...) I have the base model, so I do not have cruise control.
Also, are there any tips for climbing hills and bridges? I coast down, of course, but the engine seems to wail a bit going up. There is a new bridge in town and it is mighty steep. I get about 17 MPH going up it (at about 40 mph). Since my car is still new (just passed 2000 miles), I worry about it - don't want to damage it in any way ever.
Thanks for any advice you can provide.
Sam
There's nowhere you can be
that isn't where you're meant to be
saminjax is offline
Old 04-14-2008, 08:02 PM   #2
SpartanScott
Michigan Member
SpartanScott's Avatar
Default Re: Can't get back over 50 MPG - driving me crazy
I do plenty of 45-60mph driving. Ignoring the first 5 minute warmup, I can usually get 55-65mpg. You are right, at this speed it is not the best to do engine off coasting. Do a search for "SHM... super highway mode" which is keeping the engine on and instantaneous mpg between 70-100mpg. You can hold this for a long time, and then keep above 25 mpg when you need to accelerate. For climbing hills pre-accelerate at 25mpg to avoid high rpm 17mpg acceleration.
I'll attach a pic of what a 40-55mph trip might look like. On this trip I had a stoplight about every mile hence the constant regen cars.
SpartanScott is offline
Old 04-14-2008, 08:21 PM   #3
Rangerdavid
Rangerdavid's Avatar
Friends: 7
Here in the mountains, where its still snowing today, the weather has warmed up considerably. At this point, we can smell spring time just around the corner. The first sign is my mileage is again on the upswing!! I'm halfway through this tank and when I got home, the mileage was at 51.1 for the tank. I'm very glad. Its one of the things I love about springtime, the Prius mileage goes up over 50 again!!! AHhhhhhhhhh..........
Rangerdavid is offline
Old 04-14-2008, 10:51 PM   #4
saminjax
saminjax's Avatar
Very impressive. I would like to achieve those results.
Can you further explain "instantaneous mpg" for me, please? Is that when you get up to the desired speed (or a little higher), then let off the gas for a moment, then back on? That is how I was able to get mine up to an average of 47-49 mpg (where it has stayed even since I've returned from the trip and to my daily route). I would accelerate up, then find a place on the gas pedal where my mpg number was dropping fairly slowly and my speed was dropping slowly, but I would not accelerate until the MPGs dropped to around 60. If I'm interpreting "instantaneous mpg" correctly, I should accelerate instead when MPGs are around 70, right? I was trying to maintain around 70 MPH. I had a hard time keeping my speed steady and doing this.
When I tried to just relax and drive, my MPGs would plummet down to the low 30s. I wish I could just relax and drive, but I can't live with MPGs in the 30s because I know my car can do better than that. Honestly, I thoroughly enjoy my town driving, but I have not enjoyed my highway driving at all. I drive highway on the weekends a lot because I'm out and about. I often find myself wishing I could just relax, but I can't seem to do that when the MPGs are way down like that. I would like to learn how to do both - relax and get my MPGs up without having to think about it so much. Tell me, are your trips, like the one you provided the snapshot for above, relaxing to you or do you have to worry with watching the MPGs the whole time? I love the car and I want to eventually be able to enjoy my road trips, you know?
I still am not sure if I even understand warp stealth yet or if I ever will. The only times I have been able to do that have been on exit ramps or similar situations of reducing speed gradually for a longer distance.
Thanks for all your input.
saminjax is offline
Old 04-14-2008, 10:59 PM   #5
saminjax
saminjax's Avatar
I must be totally screwing up because my weather is warm (70-80 degrees) and I can't get my mpg back up over 50. I stealth whenever I can, just like I did before my long trip (the first one in this car), but I have not been able to get the same results that I had before that trip. I wish I didn't care.
saminjax is offline
Old 04-14-2008, 11:30 PM   #6
SpartanScott
Michigan Member
Can you further explain "instantaneous mpg" for me, please? Thanks for all your input.
Instantaneous mpg is also called "current mpg" and it is the far right bar shown in my picture above. It is also the number displayed on the bottom of the energy consumption screen. It is what the computer calculates the MPG to be at that exact point (instant) in time. Watch that bar or number and first try keeping it around 75mpg, when you need more speed accelerate above 25mpg. This method is good for 45-65 mph.
I think it is hurting you that you are doing an engine off coast instead of keeping momentum at higher speeds. You should only do that when you need to coast to slow down a hill or are coming to a stop. Once your above 40mph try not to accelerate so hard that your "current mpg" is less than 25MPG. I might suggest that you do a drive with the display OFF and just drive normally. Check it after the trip and you might notice that the car will 'fix' the MPG for you.
Read this link about this "Super Highway Mode" that I am talking about.
Pulse and Semi-glide on the Freeway?
Old 04-14-2008, 11:41 PM   #7
saminjax
saminjax's Avatar
Thank you SO much. This is so helpful. I was starting to use these techniques, but didn't know how to perfect them or the proper way to apply them. The information you posted above, along with step-by-step intructions in the links, will really help. Thanks again!
saminjax is offline
Old 04-14-2008, 11:44 PM   #8
johnval1
Talk about YMMV! My wife and I both drive the same Prius and we get about 4 or 5 mpg difference on a consistent basis - with her winning all the time. She drives very cautiously and with a light foot. Mine is a bit heavier and I suffer mileage by comparison.
Try slowing down and less acceleration. I apologize for the simplistic advice, but that is the difference between me and The Big Girl.
johnval1 is offline
Old 04-15-2008, 04:33 AM   #9
xsmatt81
non-AARP Member
xsmatt81's Avatar
Send a message via AIM to xsmatt81
I just run cruise when going up hill's to hard to fight it imo.
My mpg is back upwards of 48mpg now that I have started pulse and glideing more, and not driving as fast, also have been doing less short trips, if i do need to go out late to the store.. I will drive around a bit to even things out. Plus driving for the heck of it is relaxing sometimes later at night.
xsmatt81 is offline
Old 04-15-2008, 10:21 AM   #10
HardCase
SilverPineMica, the green one
HardCase's Avatar
Sam, be willing to bet that once you refil the tank with 100% gas you'll see an improvement in mileage. Have you checked tire-pressures? Those should be at least 42/40, and I keep mine at 45/43 and check them weekly. Tire pressure is one of the big things affecting mileage.
I wonder about turns/curves in the road too, can't recall seeing that aspect of driving discussed here.....although confess I've not done a search. I've noticed that when I'm driving on the highway and encounter a curve in the road, maybe not a real gradual 'sweeper' but a more pronounced (although not terribly so) one, mileage drops off noticeably. My sense is that maybe the lateral force being applied to the tires causes an increase in rolling resistance....but I'm no physicist nor engineer. Has anyone else noticed this?
'08 Prius
'08 Toyota Tacoma regular cab 4WD
'97 Honda Prelude SH
'04 KTM 950 Adventure
HardCase is offline
Seat Belt Holder Thingie Driving Me Crazy pvpost Prius Main Forum 3 07-20-2007 04:53 PM
HELP!! AM I GOING CRAZY!! dzeiter Prius Main Forum 13 05-15-2007 09:30 AM
Is this person crazy?¿? BitShifter01 Prius Main Forum 11 10-14-2005 12:34 PM
Here's to the Crazy Ones! macreative Prius Main Forum 0 09-17-2004 06:27 PM
Waterdrops are driving me crazy!!! V8Cobrakid Care, Maintenance and Troubleshooting 21 09-06-2004 07:19 PM
