| Prius Main Forum This is a discussion on Rented a Prius within the Prius Main Forum forums, part of the Toyota Prius Forums category; The light for Maintenance Required is on. I traveled 76 miles and it says I averaged 45.6 mpg but looking ... |
| Junior Member Join Date: Mar 2008 Location: Alabama
My Car: 2008 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The light for Maintenance Required is on. I traveled 76 miles and it says I averaged 45.6 mpg but looking at the consumption it never got under 50mpg. The big issue is after only 76 miles, it has already used up 3 blimps. |
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | The graph on the energy screen plots MPG (vertical, "y" axis) against time (horizontal, "x" axis. You are probably thinking that its plotting MPG against distance. A reasonable but incorrect assumption. I think that MPG against time is a nearly meaningless measurement. See this thread for my take on it: MFD Energy Graph; MPG-H, A Better Way? Some folks strongly disagree. You decide. As to the pips on the "Guess Gauge," welcome to the world of uncertainty. There are at least 5,743 threads about the frustration it creates. But don't worry about the pips at the full tank end of the gauge, that's not where real trouble lies. BIG trouble lies at the other end, the approaching empty, or soon to be empty, or oops! just went empty with one pip showing end. Of the 5,743 threads about the guess gauge, 5,742 are about what has happened, is happening, or will happen if you run out of gas. Nothing good can come from running out of gas. The smart folks recommend that you fill 'er up at two pips. Again, you decide. Last edited by Rokeby; 04-15-2008 at 11:38 PM. |
| Senior Member Join Date: May 2007 Location: Arlington, VA
My Car: 2007 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Maintenance Required light means it's almost time for an oil change. How many miles are on the odometer? |
| Member Join Date: Jul 2007 Location: Anderson, In.
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The maintenance required light is on not the check engine light. They are two different lights. The maintenance required light is to remind you to change the engine oil. Many people do not know how to reset the light when changing the engine oil. Last edited by SuperDave; 04-15-2008 at 11:32 PM. |
| non-AARP Member Join Date: Mar 2008 Location: Vegas
My Car: 2007 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | give this to the rental place
| Rented a Prius | MPG Nerd | Fuel Economy | 4 | 02-18-2008 04:00 PM |
| Rented a 2007 Prius at SFO | brad34695 | Prius Main Forum | 5 | 11-28-2007 03:57 PM |
| Rented an '05 Prius | OUscarb | Prius Main Forum | 7 | 11-22-2005 01:47 PM |
| Just rented a Prius | elmofongo | Prius Main Forum | 21 | 11-21-2005 04:24 PM |
| This is what happened when I rented the Prius... | macreative | Prius Main Forum | 7 | 09-04-2004 02:14 AM |
