| Prius Main Forum This is a discussion on Auto A/C settings within the Prius Main Forum forums, part of the Toyota Prius Forums category; Newbie question for you veterans -- I've noticed that if you touch the Auto A/C button on the steering wheel, ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Newbie question for you veterans -- I've noticed that if you touch the Auto A/C button on the steering wheel, when you go into climate control, it's turned on (intuitively enough) both the automatic climate control, and the air conditioner to on, regardless of how you had it set up before. My question is... with the Air Conditioner set to on this mode, does it actually use the air conditioner (condenser) all the time, or just when the car deigns it necessary to cool the vehicle down? Thus far, I've gone into climate, and made sure the A/C button is unselected, but the temperature control is still turned on... and that seems to work... but I'm not sure if I need to do this, or if the system is smart enough to lay off using the actual air conditioner when it's cold outside (or at least when it doesn't need to actively cool the cabin down from a higher temperature.) If it's not going to impact my mileage by running the real A/C system all the time, I'd like to leave it on so I can "set it and forget it," but I'll keep doing what I'm doing now if not actively deselecting A/C on the climate screen means the air conditioner (and not just fan) will run all the time. Thanks! |
I, too, would like to know the answer. | |
| Join Date: May 2004 Location: Gilching Bavaria Germany, & Drapanos, Crete, Greece.
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I have also wondered about this. However, I can say that the last few days I have needed to heat the car, and if the compressor is "enabled" than the motor will stay running at a stop. If I switch it off, then the motor goes off as well. I therefore concluded that it stays on in automatic. I would love to find Im wrong here! |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 23 | Guys I just don't think the compressor is running when the car is actually heating everything else is just too advanced and too designed to be energy saving to believe they'd do something like that. I think the thing that makes this question come up at all is the fact that they call the climate control system the Air Conditioner....if they called it climate control would we even wonder about this?? |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | [font=Comic Sans MS:4a7ae9a4e3] [size=18] That certainly makes sense. But consider this: It's recommended that the A/C compressor be "On" while heating the car if the windows are fogging up. The A/C compressor removes the humidity from the air and helps defog. (Is that a word?) |
My Car: 2004 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
| | #8 | ||
| Member Join Date: Mar 2004
I hope that helps a bit. Best, Pino | ||
| Progressive Member Join Date: May 2004 Location: Southern California
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
Before the weather turned, I have had the air conditioning on full blast in 100+ degrees Fahrenheit ambient temperatures and the ICE would shut off every time that I came to a stop as long as the traction battery was sufficiently charged. | |
| speedometer settings | volumedude | Prius Main Forum | 11 | 04-12-2008 12:06 AM |
| overseas settings? | drewsdaddy | Fuel Economy | 1 | 09-10-2007 10:56 PM |
| A/C fresh and recirculate settings | Dr Ed | Prius Technical Discussion | 1 | 07-06-2007 08:53 AM |
| Bluetooth settings | densaer | Audio and Electronics | 6 | 03-15-2005 11:16 AM |
| speedometer settings | volumedude | Knowledge Base Articles Discussion | 0 | 12-31-1969 07:00 PM |
