Prius Main Forum This is a discussion on New Feature - Disables headlight disabler!!! within the Prius Main Forum forums, part of the Toyota Prius Forums category; Here's a question for those who think this is a design flaw: How would you want it to work? What ...
View Poll Results: has this ever happened to you?
yes 3 23.08%
no 10 76.92%
Voters: 13. You may not vote on this poll
disable, door, headlamp, headlight, switch
Old 05-23-2008, 07:29 AM   #11
ForTheGlory
Default Re: New Feature - Disables headlight disabler!!!
Here's a question for those who think this is a design flaw: How would you want it to work? What if you wanted to keep the headlights on, turn the car off and stay in the vehicle (or have the passenger get out while you stay in)?
Automatic features are convenient, but I find that there's rarely a way to make something automatic without making the system more difficult to use in non-standard situations. When you have the headlight switch turned to ON, you're sending a command to the car to say "leave the headlights on". Shockingly, the car leaves the headlights on if you take some strange route to get out of the car.
That said, I do think that Toyota could make better use of the "weight on seat" sensors. I think that the MFD menus should be accessable at speed if there is weight on the passenger seat. Also, if there's no weight on either front seat and the car is off, then the headlights should turn off.
ForTheGlory is offline
Old 05-23-2008, 08:35 AM   #12
rsforkner
rsforkner's Avatar
I suppose everyone has their own idea of how this should work and I wouldn't try to speak for anyone but myself. That said...
I would like the "automatic headlight" feature to work just like it did in my 07 Camry and before that, my Chevy S-10. After more than 10 years of never having to think about headlights being on or off, I just don't think about it anymore. In those vehicles I never had a situation where I couldn't override the auto feature when conditions warranted it. 99% of the time I never gave the headlights a second thought.
I'll get used to it, no doubt. For anyone who has had a car with the auto feature, for any length of time, this just seems like a step backward. The fact that this feature is available outside of the US tells me this is a marketing choice, not a technical one.
Bob
  1. Every hour, everyone needs a smile.
  2. Every day, everyone needs a good belly laugh.
  3. Every week, everyone needs to laugh so hard that milk shoots out of their nose.
Mods: Reverse Beep, Window Tint, Wheel Rings gone, Unlock all Doors, Dash Topper, Window Guards ordered, more to come
rsforkner is offline
Old 05-23-2008, 11:31 AM   #13
ZC1
Junior Prius Owner
ZC1's Avatar
Nominated 2 Times in 1 Post
Originally Posted by Bill Merchant View Post
Solution: when you're sitting in the car, keep it in READY. Then you're always READY to go.
Great advice!
ZC1
ZC1 is offline
Old 05-23-2008, 12:29 PM   #14
SparrowHawk60
Happy to be green!
SparrowHawk60's Avatar
Send a message via AIM to SparrowHawk60
Why would anyone want the passenger to be able to turn off the lights after exiting the car? Why are folks to lazy to turn the lights off manually instead of having the car do this for them? (Yes, I know some people like the idea of having the lights come on when they get in the car. Sort of a day time running light thing.. To me it's not worth burning up the HID's for no good reason.) The Prius is not designed to have any other door control the "automatic" light feature other than the drivers side. Makes perfect sense to me. You could rewire the other doors to do this, but why? The drivers side switch for the lights can be disabled, but again why?
I fly this plane for my country, when it stops flying it's not my fault, it's the countrys." CDR Fred "Bear" Vogt. The Last Skipper of VF-33's, F-4's.
SparrowHawk60 is offline
Old 05-23-2008, 12:52 PM   #15
Sarge
Sarge's Avatar
Package: C
Send a message via MSN to Sarge
Originally Posted by rsforkner View Post
Of course, if we had true automatic headlights we wouldn't be having this discussion.
As a matter of fact, Canadian Prii come standard with Auto headlights (but we can't get HID), and they behave exactly the same with regards to staying on if you don't open the driver door. If you turn the car ON while the ambient light is low enough to trigger the full headlights, then proceed to shut the car off and exit from a door other than the driver door, the headlights will remain on.
The only difference is this is only something to worry about at night... and it is usually pretty obvious if you are walking away from a car with bright headlights shining away.
Also, for US cars without the formal Automatic feature, I don't see it as a "design flaw". Rather, it is drivers using a behaviour of the car in a manner for which it was not intended. I am sure Toyota did not engineer this behaviour so people would leave their headlights on all the time, but rather to save the occasional driver who forgot to turn their headlights off from a dead 12V battery. If you feel this is a significant risk for you, then simply turn the headlights on and off as necessary, as in a conventional car... that's all.
Kevin
Freshening Toronto's air since April 28, 2006...
My Car
2006 Prius fully loaded with Canadian Package C
Seaside Pearl with Grey Interior
Accessories
  • Toyota OEM Hood Deflector
  • Delphi RoadyXT XM Radio Receiver (using Aux-in)
  • PAC SNI-1/3.5mm line filter for XM receiver
  • Disabled Reverse Beep in June to not awaken my newborn son, born June 13, 2007!
Sarge is offline
Old 05-23-2008, 01:00 PM   #16
Sarge
Sarge's Avatar
Package: C
Well, since the US gets HID headlights and Canada gets Auto, it would appear there is some incompatibility between these features. I have heard that frequent on-off can significantly shorten the life of HID lamps, though other manufacturers such as BMW seem to mate them, so who knows.
As to why Toyota does not offer Auto on the US non-HID cars, I suspect this is a marketing plan that does not want to provide customers a reason to forego the expensive HID upgrade. They want customers to buy expensive stuff.
Sarge is offline
Old 05-23-2008, 01:14 PM   #17
edselpdx
edselpdx's Avatar
I, for one, would prefer to buy new HIDs when needed in order to decrease my chances of an accident by not using them. I do use the auto on/off feature, and once did kill a 12V battery by doing the open the passenger side door while listening to the radio when I was cleaning out the car and forget the lights. Yes, I could turn them on/off manually each time I get out of the car, but choose not to.
The efficacy of "DTRs" is well evidenced in studies in Scandinavian countries, and I live in an area where the daylight in summer is dim and we have lots of rain. Although it does also utilize more power and thus probably decreases my mileage, the financial and personal costs of an injury from a serious accident would far outweigh that. Insurance doesn't cover everything.
That said, this is my choice, and I'm certainly not telling anyone else what to do, nor would I support legal requirements for DTR's. But I'm not being "lazy".
Daytime running lamp - Wikipedia, the free encyclopedia
edselpdx is offline
Old 05-23-2008, 04:56 PM   #18
rsforkner
rsforkner's Avatar
I see Auto Headlights in the same category as Electric Windows and Electric, Remote Door Locks. Got nothing to do with being lazy. It is a matter of convenience.
Anybody want to go back to window cranks?
Bob
Old 05-23-2008, 05:40 PM   #19
alanh
Originally Posted by PaulHS View Post
I've never before seen purple bars. The ICE never started to recharge the HV battery. My question is, which of the above factors kept the ICE from starting? Thanks for any insight on this.
My experience is that the ICE won't start until it gets to 2 bars.
alanh is offline
Adding automatic headlight feature prius_in_texas Prius Main Forum 16 03-08-2008 10:45 PM
Who disables the beeping stanleyjohn Prius Main Forum 25 07-11-2006 09:02 PM
Phone dialing disables after 9km/h Masoud Prius Main Forum 8 08-11-2005 06:41 AM
Add a feature DonDNH PriusChat Website Questions 1 08-23-2004 12:16 PM
Does anyone use the chatroom feature? paulisme PriusChat Website Questions 11 06-13-2004 05:49 PM
