| Prius Main Forum This is a discussion on Mountain Passes within the Prius Main Forum forums, part of the Toyota Prius Forums category; haven't done the C with the 2k4 but the 2k3 no problem just drive it normally and it's ok. Mine ... |
| | #11 | |
I've got an 05 Prius on order...I initially had my heart set on a Subaru Forester XT but the more I looked at the gas mileage data on that one, the more my enthusiasm dampened. One gas hog is enough...we'll park the Tundra and drive the Prius unless we really need a truck. Cheers, Bill
__________________ 2005 Driftwood 'B' | |
| | #12 | |
Cheers, Bill | |
| | #13 | |
| | #15 | |
My Car: 2004 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
| | #16 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I drove through the Blue Ridge Mountains in a Prius fully loaded down with worldly possessions (both rear seats folded down and I could barely see out the back window). Also took the Prius 6000' up the Smoky Mountain range. Still got 45mpg average. |
| | #17 |
| Senior Member Join Date: Jan 2004 Location: Oakland, CA
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I drove a round trip this week over the Sierras between Oakland, CA(100' above sea level) and Reno, NV (4500'). The trip was about 200 miles each way with the peak elevation of 7200' reached about 45 miles west of Reno. I was able to keep the car above 60 mph the whole way. Milelage going to Reno was about 44 mph. The return trip (including 25 miles around Reno at 40 mph--it was rainy and snowy there) came in at 53 mph. Near the summit in each direction, the battery level dropped to 2 bars. The weather was clear with a headwind going to Reno, while on the return, the mountain section was on recently plowed freeway and through some falling snow (warm enough to liquify immediately on pavement) on the downgrade below 5000' and above 3000'. Around home, the battery level seems to stay around 6 bars. Around Reno, where the air temperature was 20 to 30 degrees cooler (in the 30s and 40s), the battery level seemed to home at 4 bars.
__________________ Alan Forkosh Tideland Pearl #9--2/9/2004 Plate: AL4KOSH |
| | #18 |
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 11 | Just a thought, I was going down a moderately long stretch of road downhill and thought I'd engage B to see what it would do. Now I know it simulates engine braking but has anyone noticed that the Prius "jerks" a little? (I guess rock is more appropriate than jerk) It sorta feels like someone is pumping the brake pedal - gently, of course. |
| | #19 |
| Senior Member Join Date: Dec 2003 Location: Aspen, CO
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I picked up my 2004 #9 in Houston on 12/27/03 and drove 1,000 miles to Denver without any problems. From Denver to Aspen was a different story as there are 2 or 3 long, steep straight mountain passes. It was cold, snowing with at 35 mph headwind. The Prius was fine for the first five minutes of each pass and then on we were on ICE only with lots of traffic. It wasn't fun as we couldn't keep up with traffic. Going down each pass quickly filled the battery but there just wasn't enough capacity to make it up the other side. Other twisty passes are fine because the ICE can generally do 60mph, which is more than necessary on curvy roads. Subsequent similar trips were not quite as bad especially in warm weather, without the snow and snow tires. All in all it's OK for occasional passes but I would use my Subaru if I had to do it regularly in bad weather. This is the only performance issue with this car. Otherwise it's great.
__________________ White 2004 Prius #9 (BC), EV kit, mud flaps, window visors, 1 1/4" hitch, leather steering wheel, Mitsubishi rear wiper arm w/20" blade. White 2007 Highlander Hybrid. |
| Mountain Passes | bredekamp | Prius Main Forum | 13 | 10-22-2007 04:20 AM |
| Lost all Power going up mountain passes | wileec | Prius Technical Discussion | 34 | 08-16-2007 09:43 PM |
| Climb every mountain..... | HaroldMelamed | Fuel Economy | 1 | 03-05-2007 07:02 PM |
| EV on a mountain road? | nomadic1 | Other Cars | 8 | 02-23-2007 11:48 AM |
| Mountain driving | The Ericsons | Prius Main Forum | 43 | 07-19-2005 05:00 PM |
