| Prius Main Forum This is a discussion on Transplant the hybrid guts into a non-hybrid within the Prius Main Forum forums, part of the Toyota Prius Forums category; Has anyone tried (and/or succeeded) in transplanting the Prius drive system into an otherwise non-hybrid? Just curious to see if ... |
| Senior Member Join Date: Mar 2008 Location: Minnesota
My Car: 2002 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Has anyone tried (and/or succeeded) in transplanting the Prius drive system into an otherwise non-hybrid? Just curious to see if anyone has been this daring yet. I stare at my non-hybrid and stare back at my hybrid, and strange thoughts like this occur. The width of the motor assemblies is narrow enough to fit into a lot of other cars. Someone with fabrication skills and access to a metal shop could conceivably get this done. But for all I know, it already has been done (or at least attempted). Last edited by Optimus; 06-10-2008 at 03:25 PM. |
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | I have those sorts of thoughts on a daily basis Haven't seen one yet though. Rob |
My Car: 2004 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 12 | I'd like to hybridise a MR2. Even thought about a Toyota hybrid powered trike. This is only thoughts with no intention to do either. Last edited by patsparks; 06-11-2008 at 12:27 AM. |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | wouldn't most traditional cars... except a bug or datsun... weigh more than the prius? |
| Senior Member Join Date: Mar 2005 Location: Colorado
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | You mean like a Camry?....... The thing about a Prius is that so many other things have been done to optimize efficiency. It's way more than just the drivetrain. |
| Wrnchs OScopes Computers oh my Join Date: May 2008 Location: Ottawa/Aylmer, Canada
My Car: 2008 Prius Package: Pioneer #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
Most people do engine or drive-train swaps to put more power into a car they otherwise like. Not applicable here. Most other cars will have worse aero and thus get lower MPG. Maybe, perhaps a body wrecked Prius could be turned into a hybrid dune-buggy or something by shedding body parts to reduce weight. But dune-buggying is more about having fun and power for a weekend or so, not fuel efficiency all week long commuting to work. Or maybe some crazed hypermiler will go the next step and build a more aero body with lighter weight. Could be cool to see.
__________________ 2008 "Canadian base" (Touring pkg 2++): PSI: 50/48. Best 40 mile RT commute max 31-44 MPH: 60 US MPG. (37-50 MPH: 54 MPG) Why: (1) thrift, (2) Priups/PHEV hackable, (3) ecology. Week 5: 1250 miles, 3MClearbra, oil lower, 50/48 PSI, Trim ring remov, ScotchGard, UOA. | |
My Car: 2002 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | I am simply asking if anyone has attempted or succeeded in doing a swap yet. Motor swaps aren't all about more horse power. It can be about more reliability, better parts availability with newer motors, better towing, better fuel economy with said towing, and perhaps now... just plain better fuel economy. I am not one to speculate at this point as to what may or may not happen if a Prius system is transplanted into another car. I am interested in finding out if anyone has done it, and what the actual results were. They could be good. They could be bad. My Celica gets 32mpg now, is light, sporty looking, hatch back, and doesn't have much power either. But if I had to speculate a little, I'd say it might do pretty well with a hybrid transplant. Why would I want to do it? I don't know.... to have something different, to have something more efficient, to be one of the first to dive into uncharted territory to see what can be done, to have a greener other car, and just plain to see if it can be done. |
| Senior Member Join Date: Mar 2008 Location: Indiana, USA
My Car: 2001 Prius Package: Base Nominated 6 Times in 1 Post TOTM Awards: 0 Friends: 1 | Quote:
I'm probably leaving a bunch of dependencies out.... -Chap | |
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Quote:
One, put the Prius drive line in a smaller/lighter car to see what its capable of. The Prius weights about 2900 lbs, and while its Cd is very good its frontal area is pretty large. A Honda Insight for example has a smaller frontal area, a slightly lower Cd, and only weighs 1850 lbs. A personal favorite would be an early 70s Saab Sonett, with a 0.32 Cd, very small cross section, fiberglass body, and 1750 lb weight despite a cast iron industrial ford V4. It was a blast to drive even with only ~70hp. How about a late 80s Honda CRX HF? Two, convertible. Sorry, the current Prius convertible option is pretty ugly. How about an HSD Miata? Cd is 0.38 (not too bad for a convertible), small area, only ~2000 lbs. Drag would hurt at high speed, but around town it might best the Prius at that kind of weight. Three, Minivan: Seems to me (and lots of others apparently) to be the great gaping hole in the current hybrid offerings. An HSD Mazda 5 could be pretty cool. 0.29 Cd, small frontal area (for a van), and only weighs 3333 lbs. Thats ~300 lbs less than a Hybrid Camry, which would probably make a better power plant choice than a prius in this case. The 5 is about the same weight and hp as a standard 4 cyl Camry, and close in mileage (23mpg vs. 25mpg comb), so it seems quite plausible you could do over 30mpg comb with a Camry HSD in a 5. To look at it another way, the 5 is lighter and probably more aerodynamic than the Escape Hybrid, so over 30 should be very feasible. That would be pretty cool considering that other than the 5 there are no minivans currently available over 20mpg comb. Not that doing any of these things would really be practical. They're just fun to think about for those that like to tinker with such things. Maybe even fun enough that someone with the spare dough may just try it here at some point. After all, people build impractical vehicles all the time. Most of the folks that do that sort of stuff just haven't gotten on the fuel economy bandwagon, yet. Rob | |
| Senior Member Join Date: May 2008 Location: Florida
My Car: Other Hybrid Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
| yet another diesel vs. hybrid comparison: Chevy Tahoe Hybrid vs. Mercedes GL320 CDI | cwerdna | Prius and Hybrid News | 4 | 05-06-2008 01:56 PM |
| Hybrid Owners Get Lobby in Washington-Petition Hybrid Incentives | hb06 | Prius and Hybrid News | 1 | 10-26-2006 10:56 AM |
| Top 10 Hybrid States and Top 10 Hybrid Metro Areas in 2005 | Tempus | Prius and Hybrid News | 23 | 05-17-2006 01:28 PM |
| sks fob guts | galaxee | Prius Main Forum | 11 | 03-25-2006 02:03 PM |
| Hybrid Tech to break production hybrid speed rec. | Areometer | Prius and Hybrid News | 1 | 01-14-2006 03:24 PM |
