| Prius Main Forum This is a discussion on Anyone ever had water in the spare tire well?? within the Prius Main Forum forums, part of the Toyota Prius Forums category; Its most likely the tail lights. If you open the hatch you can quickly see all the water runs down ... |
| | #11 |
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Its most likely the tail lights. If you open the hatch you can quickly see all the water runs down the hatch valley right over the tail light seam. Slightest leak there and you have water in wheel well. I bet if you pull all the panels away from the back of the damaged lamp you'll see a water trail below that light. Last 3 Nissan's I've owned all started leaking around the lens for some reason. I now preempt that on all cars I've owned by running a bead...a small very nice bead of clear caulk across the seam of the light assy in the hatch valley.Let it dry before closing hatch & problem solved. Good luck. |
| Spare Tire Air | Ralph165 | Prius Main Forum | 14 | 04-11-2008 10:55 AM |
| Spare Tire VS Traction Control | bad monkey | Prius Technical Discussion | 7 | 10-11-2006 01:58 PM |
| Replace spare tire with subwoofer? | DocVijay | Audio and Electronics | 8 | 09-14-2006 03:04 PM |
| Spare Tire Compartment | Sunday | Prius Main Forum | 2 | 04-13-2006 12:42 AM |
| Orange spare tire rim????? | galaxee | Care, Maintenance and Troubleshooting | 2 | 03-31-2005 01:18 PM |
