| Prius Main Forum This is a discussion on help: switching the door unlock function within the Prius Main Forum forums, part of the Toyota Prius Forums category; Misson: Open all doors with 1 press of keyfob. I've pressed the panic and lock buttons simultaneously until I hear ... |
| door, function, help:, switching, unlock |
| Member Join Date: Apr 2008 Location: West Michigan
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Misson: Open all doors with 1 press of keyfob. I've pressed the panic and lock buttons simultaneously until I hear two sets of two beeps. It wants to stay on the default setting of unlocking the drivers door only. I am doing something wrong, but am stuck. Can someone help me out here? |
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Yes! That's exactly what is happening. I've tried sitting in the car and performing the same function. No diff. I know I'm close....anybody, anybody? Last edited by Palmetto; 07-12-2008 at 11:56 AM. Reason: tried from inside vehicle |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 24 | It's been 4 3/4 years since I did this...there's surely someone who's done it more recently than that.... I guess I'd suggest you continue holding the buttons down even after the beep...seems they have to be held until you hear the door locks cycle... I may be off base....it's been a long time. |
| Member Join Date: May 2008 Location: Zionsville,IN
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | I am going to try and change mine tonight so if no one else gets back to you give me tonight and I will tell you how I did mine (well hopefully cross your fingers |
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Congratulations Becky!!! ![]() I think I have done it, but honestly, I was hoping for a different outcome. When I put my hand in the drivers door handle, or open the trunk, all the doors unlock. What I'm hoping to do is use the remote and with one push, unlock all 4 doors. Maybe this is as close as it gets. Anyway, let me know how it goes for you. Welcome to the wonderful world of Prius Land!!! Jeff |
My Car: 2007 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | It requires two button press' on the remote to unlock all the doors (and to keep them unlocked you have to open one within 30 sec). This is not settable. The "hold the two remote buttons down" only changes the way the car reacts when you reach for a door (SKS). In the default setting if you reach for the drivers door only that door unlocks. If you reach for the front passenger door or the hatch all doors unlock. They will not stay unlocked unless you actually open a door. In the alternate setting all the doors unlock if you reach for either of the three sensors (drivers door, front passenger door, or hatch). Again, they will not stay unlocked unless you open one of them.
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi David, You have confirmed my conclusion. When I leave work I always put my bag on the floor behind the drivers seat, close the rear door, open the front door get in a drive off. In the default setting, the remote pressed twice opened all doors. I was looking for a setting to press the unlock button once and open all the doors. You're saying it isn't an option and I suspected this. In the modified setting, the best I can do is put my hand in the drivers door handle to open all the doors, toss in my bag in back, then open the front, get in and drive off (all without using the keyfob). I can live with that. I'm so happy with this car, I consider my programming wish small potatoes.
__________________ I know you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant. |
| unlock the door without removing the sks from your pocket | Mary Snyder | Prius Main Forum | 21 | 06-07-2007 06:45 PM |
| Switching Synthetic Oil? | Floyd | Care, Maintenance and Troubleshooting | 20 | 04-26-2007 07:11 PM |
| Driver door won't unlock | Dave | Prius Main Forum | 7 | 08-10-2006 06:54 PM |
| Problem with toggling door unlock mode | acousticbiker | Prius Main Forum | 2 | 01-25-2006 01:40 PM |
| changing door unlock defaults | Bob Allen | Prius Main Forum | 2 | 04-15-2004 01:38 PM |
