| Prius Main Forum This is a discussion on Service Engine Light within the Prius Main Forum forums, part of the Toyota Prius Forums category; Took car in for 5000 mile service. Car had 4985 miles on it. When car hit 5000 miles the maintenance ... |
| engine, light, service |
| Senior Member Join Date: May 2008 Location: USA-Arkansas
My Car: 2008 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | Took car in for 5000 mile service. Car had 4985 miles on it. When car hit 5000 miles the maintenance required light came on. Can I reset this myself? Sure do not want to go back just to have service light reset! Last edited by penbed; 07-12-2008 at 08:40 PM. |
| Senior Member Join Date: Jul 2004 Location: El Paso, TX
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | You will find the information you seek in your owners manual. I found it there before under the vehicle services section. |
My Car: 2005 Prius Package: #5 Nominated 5 Times in 3 Posts TOTM Awards: 0 Friends: 21 | just to clarify, is this the maintenance required light or the check engine light? |
My Car: 2008 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | Thanks, Actually I found it under check engine light instructions. The light I have is service engine light. Guess The lights are considered interchangeable? Worked! |
| C'Mere Sheepie! Join Date: Mar 2008 Location: Sanford FLorida
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | yes the maintenance required light just means go do an oil change. That other light you mentioned could be trouble! |
| Engine Light on dashboard - help please :-( | bulletprooffool | Prius Technical Discussion | 11 | 06-21-2008 08:45 AM |
| Engine Light | andyprius | Care, Maintenance and Troubleshooting | 1 | 12-03-2005 10:53 AM |
| Check engine light! | prberg | Prius Main Forum | 32 | 04-08-2005 11:18 PM |
| Check Engine Light on again | GaryK | Care, Maintenance and Troubleshooting | 21 | 10-01-2004 10:11 PM |
| Check Engine Light | jerollo | Care, Maintenance and Troubleshooting | 8 | 03-19-2004 10:39 PM |
