Prius Main Forum This is a discussion on Paint Can Disaster within the Prius Main Forum forums, part of the Toyota Prius Forums category; Yesterday I was cleaning my garage, and while doing so I found a can of red spray paint where it ...
disaster, paint
LinkBack (1) Thread Tools
Old 07-14-2008, 06:53 PM   1 links from elsewhere to this Post. Click to view. #1
steveholtam
Default Paint Can Disaster
Yesterday I was cleaning my garage, and while doing so I found a can of red spray paint where it wasn’t supposed to be. I tossed it towards the rest of my spray paints, and in doing so, it rolled down the driveway. I was in the middle of cleaning something else, and made a mental note to get that paint can later. Well later came and went…
A few hours later, my wife got into her 4Runner, which was parked next to my 08 Prius. I was waving bye to her as she begin to back up. That’s when the loud POP and then hissing started. The can of paint I forgot about! This can of red paint shot out from under her car and was dancing around the driver’s side of my car, spraying paint all over it!!! It started off near my front bumper, and headed rearward, all the while spinning and spraying gushes of paint out of the split out bottom of the can. Just past the driver’s door, it managed to roll underneath my car where it died.
All this happened right before my eyes. The whole event lasted just a few seconds, and I was frozen with shock the entire time. After the coast was clear, I went over and examined the damage, which was worse then I feared. Because the spray paint was candy apple red, and my Prius is Barcelona Red, at first glance I thought I was mostly ok. That was until I saw that where my car used to be shiny red, it was now a dull red. The entire driver’s side door was now dull. The hood was half-way splattered. The front quarter panel was also hit quite well. The windshield, driver side passenger window, and the left outside mirror, on all sides were sprayed as well.
As my wife drove off, I figured, ok, first let the paint dry so I don’t smear wet paint all over. After it dried, I attempted my first idea, that just by using my finger nail, I would be able to gently scrape the spray paint off. Nope. I tried this on a few tiny paint dots, and I could tell that the scraping force required would most likely scrape the clear coat at the same time. Next up was just a good old washing with soap and water. This did nothing at all, except remove the dirt on my car revealing that my car was even more painted then I first thought.
Next up, and my last idea, chemical warfare, Goof Off. I had this bottle from some project a few years ago, and remembered how caustic and powerful this stuff was. I was VERY nervous that the Goof Off would devour my precious clear coat. I dripped a few drops onto a Q-Tip, and found a test drop that would not be visible very easily in case of disaster. Well, the Goof Off instantly removed the spray paint, and didn’t seem to harm the clear coat. I tested this in a few more spots, and the red spray paint was coming off! A couple of nice terry clothes later, and most of the paint was off the metal panels of my car. Now on to the plastic, windows and trim pieces of my less then six month old Prius.
After my great luck with the painted parts, I figured the plastic and trim would be even easier. Not so! The Goof Off removed the paint, but it also ended up melting the plastic and removing the paint from things like the windshield wiper arms. Not good. My first effort really marred up some front cover thing below the windshield. (See Photo). I soon discovered that a tiny amount of Goof Off applied, and then immediately wiped off would remove the paint and take just a tiny layer of plastic with it. By doing an entire part at a time, I could dissolve the part equally all over so there was no sign of my cleaning.
I worked on this for a couple of hours and removed about 75%. I was tired and a bit frustrated so I saved the rest for tonight. I didn’t take a picture before, but here are two pictures taken today. The window picture shows how much was sprayed at that level. Lower was MUCH worse, especially as the door flares. The lower half of the door was nearly covered entirely.
All I all, I think I will be ok. Sharing this odd tale at least allows others to know that Goof Off removes paint. Just don’t use it on plastic, trim, or rubber.
steveholtam is offline
Old 07-14-2008, 06:58 PM   #2
Joekc
Joekc's Avatar
Default Re: Paint Can Disaster
Why don't you just file it under insurance comprehensive? It probably wouldn't raise your rates. Sounds like way too much grief.
Joekc is offline
Old 07-14-2008, 07:01 PM   #3
effwitt
Paparazzi Magnet
effwitt's Avatar
My car was in a parking lot and a painter was using a remote corner to paint some metal railings and overspray got all over my car. The painters had someone pick up my car and they wer able to remove the paint without damaging the paint on my car. Check with an autobody shop or detailer - they might be able to clean it up. Good luck.
effwitt is offline
Old 07-14-2008, 07:17 PM   #4
fcc
and here i thought my first tiny scratch was something to worry about :-|
fcc is offline
Old 07-14-2008, 07:29 PM   #5
chrisspaulding
sexy, high tech, fun
chrisspaulding's Avatar
Friends: 5
Dang, that really sux! Sorry to hear. I know how one little scratch can cause anxiety. All that spray??? Must have been insane!
Why didn't you hose it down with water immediately?
Maybe you can claim it on your insurance?
Hope it's not too much trouble to fix. Make sure to post the resolution!
Best of luck
chrisspaulding is offline
Old 07-14-2008, 08:00 PM   #6
fcc
I thought most spray paint was oil based especially if older and lying around
a garage.
fcc is offline
Old 07-14-2008, 08:15 PM   #7
MagneticGrayIndy
06Prius;94M Miata;65Rambler770
MagneticGrayIndy's Avatar
I tossed it towards the rest of my spray paints...
well there's a bit of foreshadowing for you.. Sucks. But the glass should be very easy.. a nice, new, clean razor blade should do the job.. Plastic?? I dunno man.
MagneticGrayIndy is offline
Old 07-14-2008, 08:20 PM   #8
chrisspaulding
Friends: 5
a garage.
ive got this cool setting on my mr clean car washing adapter(fits on the end of the hose) that sprays soapy water. i would of had that on full blast with a soapy microfiber mit washing the heck out of it before it dried.
but hindsight is 20/20
before you melt any more plastic, etc., turn this into your insurance and fix it proper, before you're too far at intentional fault.
Old 07-14-2008, 08:20 PM   #9
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Nominated 3 Times in 2 Posts
Friends: 6
I would have retrieved it right away, but that's hindsight.
I also would have got a cloth with paint remover or goof off or something and started to remove it while wet. Also hindsight.
At this point....bite the bullet and take it to a professional detailer. Hopefully they won't charge you extra for trying to do it yourself first.
Godiva is offline
Old 07-14-2008, 08:34 PM   #10
BDDave
BDDave's Avatar
Unhappy Re: Paint Can Disaster
This may be far out but if you would have turned the car around, put out another can of paint and waited until your wife returned you might have ended ended up with the same effect on both sides. When you sell a used car with a "custom" paint job you can ask a higher price.
Now seriously, what a mess! Take it to a body shop for their opinion.
BDDave is offline
LinkBack to this Thread: http://priuschat.com/forums/prius-main-forum/50900-paint-can-disaster.html
Fingernail Off - Wellsphere This thread Refback 08-22-2008 07:37 PM
Minneapolis Disaster john1701a Fred's House of Pancakes 37 07-28-2008 01:13 PM
The Derrivative Disaster Explained daniel Fred's House of Pancakes 0 06-05-2008 03:57 PM
Nav disaster !!! LuJac Audio and Electronics 5 12-17-2007 10:23 PM
Disaster Avoided Spunky Prius Main Forum 3 03-13-2006 12:33 PM
5,000 Mile Service - Almost A Disaster govisbob Care, Maintenance and Troubleshooting 18 06-01-2004 04:12 PM
