| Prius Main Forum This is a discussion on Check Engine due to Rock hitting underside? within the Prius Main Forum forums, part of the Toyota Prius Forums category; We drove our Prius on some dirt/jeep roads in the mountains last weekend and heard a couple of rocks hit/scrape ... |
| check, engine, hitting, rock, underside? |
| Member Join Date: May 2005 Location: Boulder, CO
My Car: 2004 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | We drove our Prius on some dirt/jeep roads in the mountains last weekend and heard a couple of rocks hit/scrape the bottom of the car. Then I noticed the "check engine" light was on. It went away after ~10 restarts. I checked the bottom of the car, and just saw a few scrapes. Also, my Prius still drives fine (300 miles later) and still gets great MPG. Any idea why it would have come on? ( I don't have a scangauge) |
My Car: Other Non-Hybrid Package: N/A Nominated 15 Times in 1 Post TOTM Awards: 1Friends: 0 | I think the check engine light was your Prius calling out for mercy. Prii were not designed as an off road vehicle. Straighten up bub . . . or we will be forced to come rescue your car from being tortured like that. And speaking of straightening up . . . you may want to consider having an alignment done real soon. |
| Member Join Date: May 2008 Location: Massachusetts
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | You may have pulled loose a connection to the emmissions equipment or broken a wire. I know that the secondary O2 sensor on the cat. converter would give similar indications if it was damaged. |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | I've done a lot of 4x4ing myself. there's only 1 thing i would be rather worried about while going on the 4x4 roads. if the car ever bottoms out, you risk cracking the casing that runs the high voltage lines. it's a plastic sleeve that runs parallel to the car's main body panels. It's pretty safe, but i would imagine it would cause major problems if it were to ever be hit and started to ground out in any form. Other than that.. I've never seen any error lights in these situations. I have had rocks get jammed in the engines control arm.. which makes the engine really really rough because the arm no longer dampens do to rocks being in it's travel path. oh yeah... another thing to watch out for when 4x4.. bending your rear plate (bt tech or stock) it's very easy.. as I've destroyed a bt plate already.
__________________ Silver 9 as of June 12th '04 (over 101k Miles now) Decals, Mud Flaps, BT Tech Rear Brace, coastaletech 2" receiver hitch, and 215/45/17 tires. |
My Car: 2004 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Yep, I know I shouldn't drive rough roads (or in deep snow) with my Prius....but I do, although my offroading doesn't sound anywhere close to as bad as that of V8. OK, I would be worried about emissions or cracked cases etc. too if the light had stayed on. But since it cleared after a few restarts, I assumed that it means the condition is no longer present (i.e. it's not anything permanent). Could the light come on just because it sensed a shock or something? |
| Senior Member Join Date: Feb 2004 Location: Roy, Washington and Nanaimo, Canada
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | It could have been coincidental and not have any thing to do with the rock strike. If you are close to a 5000 mile oil change warning it the light will come on for a time and then go away. |
| Senior Member Join Date: Mar 2008 Location: Minnesota
My Car: 2002 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Do you know what the code was? That would help a lot rather than just guessing what could have happened. If you had an older vehicle with a rusty exhaust and no OBDII, I'd venture to say you cracked the exhaust, opened up a gap at one of the joints, put a dent in the exhaust somewhere, or yanked some wires out somewhere. If the light comes on again, make sure to get the codes scanned. |
| Junior Member Join Date: Oct 2004 Location: uptown, chicago
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | This happened to me recently. Strangely, it was shortly after an oil change. The explanation was that i must have hit a rock that broke the headlight auto leveling sensor. I checked it out with two different dealerships and did some searching here. It seemed legit. It cost about $350 to have fixed. good luck |
| Check engine light - below 0° | strongp | Care, Maintenance and Troubleshooting | 10 | 01-17-2007 02:17 PM |
| check engine light | frazidlo | Prius Technical Discussion | 3 | 12-09-2006 01:57 PM |
| Check Engine Light on again | GaryK | Care, Maintenance and Troubleshooting | 21 | 10-01-2004 10:11 PM |
| Check engine light came on... | Patman36 | Prius Main Forum | 8 | 08-11-2004 08:24 AM |
| Check Engine Light | jerollo | Care, Maintenance and Troubleshooting | 8 | 03-19-2004 10:39 PM |
