Prius Main Forum This is a discussion on Tire Pressure - Portable compressor within the Prius Main Forum forums, part of the Toyota Prius Forums category; :idea: For Christmas, I gave my Prius a portable 12-volt compressor to keep tire pressures at optimum. It is a ...
Old 12-25-2004, 03:05 PM   #1
Charles Suitt
Charles Suitt's Avatar
Send a message via Yahoo to Charles Suitt
Default Tire Pressure - Portable compressor
:idea: For Christmas, I gave my Prius a portable 12-volt compressor to keep tire pressures at optimum. It is a "Tote" brand bought at a local Dept Store (torn box) for $7.88, good up to 250# and has an on-board gauge. This compressor is compact enough to be carried in the left side rear storage compartment. I found similar compressors at Wal-Mart for under $9.96 but no gauge.
Found my tires at 35#± front and 30#±. Now up to 42 and 40. I'll now see what difference in MPGs I get. I also gave Prius a set of chrome valve caps.
Charles Suitt
Dallas Texas
2007 Touring Edition
(Former Prius: 2004)
Charles Suitt is offline
Old 12-25-2004, 05:49 PM   #2
jamarimutt
Default Re: Tire Pressure - Portable compressor
Since you'll most likely use your compressor at home, I suggest buying an electric one too; it will pump air much faster and won't use energy from the auxiliary battery.
jamarimutt is offline
Old 12-25-2004, 06:26 PM   #3
Frank Hudon
I was in my local tool supply house the other day and they had a rechargable compressor that looked just like a portable drill, where the chuck would be was the air chuck which you put on the valve stem. Only 60 lbs output but lots of volume which is what the little 12 volt ones lack. Mind you it was $48 so I just kept thinking I'd use my spare or my home compressor.
Frank Hudon is offline
Old 12-29-2004, 02:10 PM   #4
inkydoo
I would recommend you doublecheck the accuracy of the built-in gauge with some other gauge. I have a compressor that is several years old (I don't remember the brand) and its gauge is not very accurate (it sometimes reads 4 or 5 psi too high). It was a gift, and it fills the tires plenty quick so I keep it around, but I always doublecheck it with a simple mechanical gauge.
inkydoo is offline
tire shop broke a TPMS tire pressure monitor sensor during tire change theorist Care, Maintenance and Troubleshooting 28 04-18-2008 12:53 PM
Portable tire inflator? PriusRos Care, Maintenance and Troubleshooting 80 01-29-2008 03:26 PM
Replace spare tire with 12 volt compressor? smdobson Prius Modifications 14 10-04-2006 11:51 PM
Looking for good portable cordless tire inflator jaguaraja Prius Main Forum 3 03-17-2005 01:35 PM
Good home air compressor / tire inflator? pshady Care, Maintenance and Troubleshooting 8 11-08-2004 02:23 PM
